Part of a Loom
Part of a Loom
Anyone got a loom they don't mind hacking? All the spare looms I have are complete and unmolested (no alarms etc).
I'm trying to fix a friends 206 and the speed sensor connector has broken clean off the connector. I'm after another connector with about 6" of wire so I can graft it on. It's got to be off a later 306 (or 206). If you give me a pic of the connector, I can confirm whether it's the right one or not.
Thanks.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
white power timer type plug with 3 pins?
(27-06-2016, 11:56 AM)welshpug Wrote: white power timer type plug with 3 pins
Just had a look at junior timer plugs and they're not compatible with the speed sensor (slots are different).
[Image: 3-pin-Bosch-AMP-Junior-Power-Timer-JPT-C...or-Kit.jpg] [Image: 100-Bran-new-Speed-Sensor-Fit-For-Peugeo...616070.jpg]
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
they are, if you get the white ones, theyre still a jpt plug.
All sorted, went to the scrappy.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
