Threads: 47
14
Car Model/Spec: Ford cougar v6. Mk6 Transit
Given 20 thank(s) in 20 post(s)
I would drill the head off, remove the shock, heat up whatever it bolts into red hot and try mole grips, if that failed i would get the welder out and weld a new nut on, hope the heat from welding did something and try again.
If none of the above worked i would get the drill back out and drill it out completely and re tap it.
Massive ballache basically.
I Don't Have A 306.
Threads: 102
9
11-06-2016, 12:44 AM
(This post was last modified: 11-06-2016, 12:46 AM by procta.)
research what replacement bolts are needed before you even go any further then
I would drill the heads off, remove the shock, and drill them out completely and re tap.
Threads: 47
14
A cheap drill, some bits and taps will most likely be the cheaper option.
I Don't Have A 306.
Threads: 386
87
Surely cheap drill bits and taps will be shit and make it worse though?
Threads: 541
124
If you can't use fire or weld then definitely drill and tap. It'll definitely take a while if you have shit bits but it's probably the best way unless you want to pay for it to be done.
I reckon 2-54 hours labor if you pay a garage to do it.
Threads: 62
10
Given 11 thank(s) in 11 post(s)
Looks a crap design but then it's a Ford.id smash a 6 sided impact on there or find a friend with a welder to weld a nut onto it.
HDi Owner for 200k/9 years
Threads: 386
87
It is a crap design, can't even see the need for it. There's a hole in the arch I'm the boot tovaccomodate the top of the shock...but it's not big enough to get the 13mm nut off...if they'd just made the hole bigger it wouldve been a 10minute job and they'd have saved on metal...not much per car but the Fiesta is the biggest selling car in the uk iirc!
Threads: 371
29
Car Model/Spec: ford fiesta
The more i think about this the more i think ive never had to remove those bolts. Ive got sockets that fit in there for this exact reason.
Threads: 371
29
just run it up to purlings during the week between 12 and 1 when im on lunch and ill take a quick look for you
Threads: 371
29
yeah just drop me a message and let me know what day is good for you and ill work round it
