Thermostat screw
Thermostat screw
I've a sheared thermostat screw (gti6 engine).
Is it a standard thread? I'm hoping I can get the remnants out without damaging the threads in the housing!
Bianca Rallye
1989 205 GTi6 on ITBs
BMW Z4 3.0
Thousands of GTi6 parts availabile.
is it too far gone for easy outs?
might want to warm the area up with a tourch, then quench it with wd40 or plus gas, this will help draw the wd40 or plus gas in and help free off the thread, then try easy outs Smile should work quite well.
Not always Grumpy!!
306 Cabby SE, 2.0l 16v
Standard M6x1 thread from memory Dan
I can't remember precisely what thread but yes it's a standard size and a normal bolt works fine.
62k Diablo Phase 1 Gti-6:
Project Thread
Thanks for the replies guys. I was very lucky to be able to use a tiny screw driver in the centre hole and undid it effortlessly.
It was longer than I'd anticipated so it was easy to compare to another screw to check the threads and confirm they are standard M6 pitch.
Bianca Rallye
BMW Z4 3.0
  Mocal Thermostat Pingaz 1 9,408 22-06-2022, 09:05 PM
Last Post: Stef205
  How to remove this rounded screw MisterGTR 14 6,168 31-08-2014, 05:01 PM
Last Post: MisterGTR
  Thermostat - GTI rocker8742 6 4,567 10-03-2013, 07:30 PM
Last Post: Frosty
