Threads: 90
54
I would remove myself, as would i remove the coating at base of bolt holes, I have seen wheel bolts loosen up over this exact issue before, and it is a common problem on agri wheels! Normally just ringing the bolts up a few times/ removing lossens it enough to just flake out....
Threads: 61
11
Yes I did a trackday on freshly done wheels once came in after 5 laps to do a bolt check to find the fronts finger tightness! !
Threads: 127
33
Car Model/Spec: ZX Volcane TD
remove - also, swish wheels innit
Threads: 591
54
Yeah.
On rallye wheels, often get coating each new season.
So beginning of year we spend time decoating the mating faces. We had a long drill bit/wire wheel for the bolt faces
Threads: 15
Car Model/Spec: XUD9 Sigma Blue Phase 1
Given 3 thank(s) in 3 post(s)
Que the buzz gun and a spare wheel nut lol
Threads: 42
28
definitely remove, they'll never balance up properly and they can come loose, they wont stick to the hubs.
