Radiator XUD
Radiator XUD
My ZX 1.9D no A\C as a leak in the radiator that I have to change it soon. In the future i want also to replace the engine for a XUDTE (turbo).
I measured the depth of the radiator and its 2,3 cm, its this model from Valeo : http://www.mister-auto.pt/pt/radiador/va...31010.html
Is it worth to replace with a bigger one like this: ?  http://www.mister-auto.pt/pt/radiador/va...31181.html  (40mm)
Or pay the twice as much and upgrade to all aluminum: http://www.ebay.co.uk/itm/PEUGEOT-306-TU...SwT6pVsJ-o
i like Alu, if you can afford it go for it, see if you can get a Nissans one, will last forever and give better needed cooling if you tune her up . .Smile
there are issues with that aluminium rad - for starters the bottom hose connector is wrong
Id go nissens unless youre going on track with it. quality us good. worth the money imo. track needs a lot more cooling and as tom said the rad doesnt look right either
I'm inclined to buy this one: http://www.mister-auto.pt/pt/radiador/ni...1326A.html
