Car Model/Spec: 306 D Turbo
Will a phase 3 set of doors and boot lid fit my phase 1(5 door)? I am guessing yes but wasn't sure if the hinges or locks are in a different position.
Reason is mine are all very tatty, grey door handles, mismatch door cards, etc.
Cheers
Threads: 36
18
Car Model/Spec: DT
Can't read... ignor!
On the 306 waiting list.
No no, lol!
5 door to 5 door!
Threads: 150
14
Car Model/Spec: 306 HDI
i think they should just fit straight on mate
306 HDI, soon to be XUD
Threads: 183
20
Iirc isn't the rear lock different from 1 to 2-3
Threads: 150
14
oh seriously? my bad
Threads: 171
46
kentiiboii Wrote:Iirc isn't the rear lock different from 1 to 2-3 they have a lock surround wit hbadge, as to whether its different inside i dunno
they do however differ loom wise and rear wiper so will be a right pig and you will need to rewire it
21
This is precisely the French gayness I mean. AFAIK the lock surround is.different but the lock itself is the same. Just need to be sureish before I go at it.
@kingy I can't get rid of trixy! I've thought about it lots of times but I love the old girl. Plus I enjoy having one of the oldest cars on the road by me! She just really needs some exterior tlc.
Threads: 171
46
didnt you read my post? the wipers are in different locations and the loom need cutting and rewiring
4WayDiablo Wrote:didnt you read my post? the wipers are in different locations and the loom need cutting and rewiring
Yea mate, I did. I'm not too fused about the wiring, there's not that much in there, lock (mine doesn't work anyway), demister and wiper. Shouldn't be that hard to wire.
Main thing I wanted to know was the physical locations of the locks and hinges and will it all line up?
Threads: 177
The loom comes out of the boot lid, theirs no need to cut it
Threads: 96
7
Car Model/Spec: 306 tractor
I changed my boot lid, what a bastard to pull the loom from your car through the new boot-lid but the washer pipe didn't happen-routed it internally!
Basically I don't envy you with what you're planned, try and get doors with the same looms to reduce your work
Threads: 189
10
Car Model/Spec: E39 ACS 535i
It'll all bolt on fine.
Ph2/3 boot looms will need to be changed for ph1 one
Doors can be left as is, but will require a non auto window switch to function properly (will blow fuses otherwise)
Threads: 16
Sorry, but I think the main problem is 3 door and 5 door doors are different sizes. So they won't physically fit the gaps... Or will be too big, dependent on which way you look at it I guess!
Threads: 198
135
burnmw Wrote:Sorry, but I think the main problem is 3 door and 5 door doors are different sizes. So they won't physically fit the gaps... Or will be too big, dependent on which way you look at it I guess!
Reading fail
Threads: 16
cwspellowe Wrote:burnmw Wrote:Sorry, but I think the main problem is 3 door and 5 door doors are different sizes. So they won't physically fit the gaps... Or will be too big, dependent on which way you look at it I guess!
Reading fail
Pahaha yup...  I thought the OP said 3door on to 5door, rather than P3 in to P1 5 door. D'oh!
Threads: 198
135
..but thank you for your contribution, captain obvious
Threads: 36
18
Car Model/Spec: DT
It's ok mate I made the same mistake but ninja edited or before anyone saw!
