03-02-2016, 06:05 PM
Where is the best place for mail order pup parts please?
mail order parts
03-02-2016, 06:07 PM
what are you after?
https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
03-02-2016, 06:29 PM
Want to avoid a 100 mile round trip to the crappy local pug dealer!
Was after a new or good s/h 306 ph3 estate number plate light unit and some clips for the bottom tail gate clips, the ones with a screw slot ( ? ) in them but they slide onto the trim mounting, they have 3 legs all attached to the clip, legs to base and "top". Can post a pic if that helps, or possibly a part number as now can get into service box parts section.
03-02-2016, 06:58 PM
The plate lights are cheap new on ECP, or at least they are for hatches, not checked estates.
03-02-2016, 06:59 PM
put the part number into ebay im sure it will be listed
03-02-2016, 07:38 PM
the ecp one looks the same, at £3!!! only half hour bus ride away, thanks.
03-02-2016, 08:10 PM
Will be going to ecp tomorrow to get the one light they have in stock, after phoning and checking, but they dont stock everything, so could anyone recommend a mail order pug parts supplier Please.
Also which are the best rear suspension beam mounts, the ecp febi or the ecp fordsummut, forgotten that brands proper name but they do loads of stuff. Thanks.
03-02-2016, 09:00 PM
aepdirect.com is what i use
Thanks given by: pug306driver
04-02-2016, 11:56 AM
Thanks, will check them out.
04-02-2016, 03:34 PM
| in what order | Magenta Sunset | 22 | 11,425 |
24-04-2016, 08:51 AM Last Post: Magenta Sunset |
