Threads: 5
Car Model/Spec: 306 gti6
Country:
hello I'm currently building a car to use in autograss its a 306 gti6.1998 model.
I need help to have the ecu unlocked so I can get rid of the immobiliser/ transponder key and barrel from the column .
I live in south wales so any advice on who can unlock it would be helpful.
also I thinking of changing the g/box to a 5 speed can anyone recommend a g/box to use please.
Threads: 16
1
Given 3 thank(s) in 3 post(s)
10-01-2016, 12:06 PM
(This post was last modified: 10-01-2016, 12:07 PM by roland rat.)
Your best off buying an unlocked ECU from Rich Walker on the 306 gti6 forum.
Gearbox wise I'm guessin you want just quick acceleration so look at a 205 1.6 be gti box I'd say
Threads: 15
2
Car Model/Spec: XSi
10-01-2016, 12:15 PM
(This post was last modified: 10-01-2016, 12:16 PM by adam b.)
Nah, use a 1.9/early xsara vts with a 4.8 in it
As for transponder you'll need the immobiliser to give a signal to the ecu to run as standard. For the faff just rewire the ignition, split off the key barrel surround and fix a chip out of a key to it. Weight is bugger all.
And get a diff
And change the power steering ram to a 5 speed one
P1 XSi track car
2.4 LWB T4
Threads: 16
1
He's known as rich_w on the gti6 forum
