Threads: 83
Right been sat here pondering... can't really remember through all the threads in the past but did anyone ever find out if there is an OE clutch that goes in a van or something like an 806/807 or something that's a little more heavy duty than a standard 306 hdi clutch. I've ran a stage 2 map on my hdi for 60k miles now and it's starting to slip occasionally. It's the origional peugeot item so it's done pretty well. Well enough to not justify 300+ for a helix or something.
So if there was a more heavy duty one that would be perfect for me
Threads: 371
29
Car Model/Spec: ford fiesta
Xud style conversion or berlingo clutch.
Threads: 21
Car Model/Spec: Stage 3 HDi
Given 5 thank(s) in 4 post(s)
The berlingo clutch is the same as the normal 306 one, same part numbers
Threads: 70
10
Car Model/Spec: HDi Estate
Given 9 thank(s) in 9 post(s)
04-01-2016, 08:25 PM
(This post was last modified: 04-01-2016, 08:27 PM by tigerstyle.)
Did I just fit a 306 Hdi clutch when a Berlingo would've been a sneaky upgrade?
Oh, just seen the last post, maybe not then
Threads: 371
29
Ok thought it was an upgrade. Could be wrong though so really don't quote me on it. I remember more about xuds really.
Threads: 10
The 806 has a different gearbox with a 21 spline input shaft. Clutch wont fit a 306.
Threads: 42
28
any decent output HDi van will have an ML box as mentioned.
