Hdi Van Clutch
Hdi Van Clutch
Right been sat here pondering... can't really remember through all the threads in the past but did anyone ever find out if there is an OE clutch that goes in a van or something like an 806/807 or something that's a little more heavy duty than a standard 306 hdi clutch. I've ran a stage 2 map on my hdi for 60k miles now and it's starting to slip occasionally. It's the origional peugeot item so it's done pretty well. Well enough to not justify 300+ for a helix or something.
So if there was a more heavy duty one that would be perfect for me
Xud style conversion or berlingo clutch.
The berlingo hdi or 1.9?
The berlingo clutch is the same as the normal 306 one, same part numbers
Did I just fit a 306 Hdi clutch when a Berlingo would've been a sneaky upgrade?
Oh, just seen the last post, maybe not then
Ok thought it was an upgrade. Could be wrong though so really don't quote me on it. I remember more about xuds really.
The 806 has a different gearbox with a 21 spline input shaft. Clutch wont fit a 306.
any decent output HDi van will have an ML box as mentioned.
