ABS Removal
ABS Removal
Looking to remove the abs to make way for a decent location for the air filter. Is it as simple as ripping all the pipes out then making my own lines up? Going from 1 port on the MC to a T-piece for the front the the second MC port to another T-piece for the rear like this picture? I'll just miss out the bias valve as its for the DT
Exactly this did it on my hdi tho ngl was pretty pointless [Image: a45e9d75ab4ea690c3afc2b8525b074f.jpg]
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Struggling to find a decent place for the filter so think it would be the best option Smile my abs hardly works anyway haha can lock the wheels up. Where is your PAS bottle too?
It's not working at all if you can lock the wheels...someones probably pulled the dash bulb... Tongue
Have you still got drums on the back? Would need a bias valve for discs.
(18-12-2015, 12:36 PM)Toms306 Wrote: It's not working at all if you can lock the wheels...someones probably pulled the dash bulb... Tongue
Have a disk beam with the load compensator
Ah ok, load compensator is the bias valve. Smile
Personally I like ABS for emergencies but if you do want to remove it then it is as simple as you've suggested above.
be careful as technically it will fail its MOT without the abs as the car was built/sold with ABS
GTI6 Info
(18-12-2015, 01:25 PM)cully Wrote: be careful as technically it will fail its MOT without the abs as the car was built/sold with ABS
Could I not pass it off as a model without abs? Like a lot of xud's
id personally run a diagonal split from to rear from the mc
(18-12-2015, 03:09 PM)zx_volcane Wrote: id personally run a diagonal split from to rear from the mc
Could you explain a little more please? Smile sorry still learning lots haha
Diag split,
basically tee's o/s front to n/s rear & n/s front to o/s rear.
1 cct to each port of the m/c.
Hate Housework!
Ah okay what's the advantage of doing that
If you get a split brake pipe you can still brake in a straight line in theory.
(18-12-2015, 04:55 PM)Toms306 Wrote: If you get a split brake pipe you can still brake in a straight line in theory.
Ah makes sense so will i T off near the bulk head
1. i cant see why you would remove a factory-fitted safety feature to fit a "better" air filter ?????? someone has already said its pointless....(filter mounted under bonnet surrounded by warm air)
2. when the car chassis number goes into mot stations computer it will print out that the car has ABS and it needs testing, so car will fail the mot test.
3. why not fit a k&n or a green cotton replacement filter in the original airbox and run a cold air feed pipe to the box ?
More control if you have a bias valve to the rear brakes. Unless you can load compensate then diagonal will lock the rears all the time. This time of year on cold tyres mine does it a lot...
No issues at all on mine for the mot
I prefer it without ABS to be honest. Always felt it kicked in too early. Lots of weight out and it's much easier plumbing in a hydraulic handbrake
P1 XSi track car
2.4 LWB T4
