Wanted: Water injection stuff
Anyone got any kits, bits, pumps etc unwanted?
What you got and how much?
Smile
Got a spare nozzle 04 here, but will need to double check
You know all about pumps iirc, most are rebranded shurflo which you can pick up for reasonable money
Same with push fit connectors, piping and all that, think caravan water systems ..etc
Control pump with arduino, or get a simple pressure switch.
Only other thing you need is a decent check valve.
job done
Yes, PM'd.
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
(08-12-2015, 08:12 AM)zx_volcane Wrote: Got a spare nozzle 04 here, but will need to double check
job done
Yeah just got me a adjustable pressure switch and piping is no issue too as you say...
May have sorted a pump now so can you check on that nozzle for me?
Any pointers to check valves other than the £35 one from devilsown? Most have a very low cracking pressure...like 2/3psi. Needs to be 15/16psi afaik
not sure on check valves, could be a custom job aka devilsown or similar due to opening pressure
deffo got a spare 04 nozzle here
That a 4gph nozzle?
Message me ThumbsUp
  Wanted: Bosch Injection Pump pugmanxud 2 2,289 11-04-2014, 08:30 AM
Last Post: pugmanxud
