Service Schedule?
Service Schedule?
I have made up a quick service schedule for my car. I am useless at remembering what I have done when haha. I intend to keep the car running sweet for as long as possible really. Here is my quick schedule. Is there anything you recommend me to add or millages for things I should change?
It currently is this. With the colours showing the mileages at which each item/fluid would be changed Smile
[Image: dov3wj.jpg]
Thanks Big Grin
Might wanna add brake fluid.. Its about 2 years iirc.. Depends how long you have the car lol
only thing i'd do different is fuel filter same time as oil & air. (My personal pref) you'd have the hood up anyway lol
Hate Housework!
Coolant and gear oil don't need changing that often really. In fact nothing needs changing that often on these, I know you're trying to preserve it but changing oil at 6k on a DW10 is a waste of oil and money really, especially when you're using genuine parts.
Yearly or 10-12k is fine for oil and filters on these. Coolant should last at least 3 years+. Brake fluid every 2 years but not many do that lol. Gear oil when you do a clutch or driveshaft, doesn't need to be routine.
My gear oil does need doing apparently I have a leaky gearbox seal :/
Well there you go then, once that's replaced it probably won't need doing again under your ownership. Smile
Need to get it sorted tbf. Only got told it by the people that did my clutch. Daft really considering they had it all apart and could have flippin changed it.
They probably damaged the seal on the way back in...cant really reuse old ones, I've made that mistake before. So much more difficult to change once it's back in the car as well. Dodgy
You'd be mugging yourself with that kind of schedule. If you drive very hard changing the oil every 6000 isn't overkill, but the rest of it can wait a lot longer. The air filter won't need changing more than every 15k, fuel filter 20k, coolant almost never - pretty sure that stuffs good for 6 years or something daft.
Yeah, any OAT coolant is fine for a good 5 years. I changed the stuff in my V50 for the first time in 10 years when I did the cambelt, checked it, was absolutely fine - no signs of any corrosion or changes in thermal protection...
Oil if you're driving hard and with a map on, it's fair to drop it to 6k or so. Fuel filter - meh, again, driving hard doesn't affect it, buying a good quality genuine filter is all you need. Air filter - get PP2k and monitor your MAF flow, any point it starts going down you can replace the filter and be sure that you're never impacting on performance.
Awesome. And yeah it does get driven well on ocations haha Tongue
As for stuff like that air flow meter I need to get my self an old laptop first. Only have windows 7 and apparently it don't work with that.
Users browsing this thread: 11 Guest(s)
