Where to find new front brake callipers quite cheap?
#31
Think its worth changing the master cylinder then? Its on its original one from the factory as far as I know.
Checked and seems fine from the engine bay Smile
#32
Sounds like you'd be better off taking it to a garage. I'd be amazed if it's much more than a half hour job to sort it. Sliders stuck or pads stuck would be my first suggestion, failing that it'll probably be the pistons.
  Which callipers will fit under my c5 "steelies?" Xsikid 6 6,465 05-06-2017, 04:42 PM
Last Post: Xsikid
  Disconnecting rear brake lines at the front Iaitoo 21 10,808 04-06-2016, 08:22 AM
Last Post: pug306driver
  New Cheap Front Lucas Calliper Suggestions MY95 4 2,949 19-04-2015, 01:40 PM
Last Post: titch
