1.9 dturbo looking for some ideas on what do do with it
[Image: 90da15659406b87e5b61598238206a4c.jpg]
Best thing to do with that is drive it to Glasgow and give it to me!!! ;-)
Missed a bit on the sill Wink
Tell us whats been done already and im sure we can suggest some well proven things to compliment it Smile
Team Cyril
Just bought the car all I've done so far is lower it turned the pump up a little bit need to sort out a half decent exhaust before I tune any more [emoji594][emoji100]
[Image: 3c5d1e9ab1dc1cd3b76e066a3616ee95.jpg] do phase 3 lights fit directly on this?
Looks like its already got a ph3 front end on?
Team Cyril
I don't have any pictures of it front on but it's got square fogs and the lights are dip/main same bulb was thinking it was ph2
My bad! it does look ph2 with half rounded foglights.
But yeah ph2/3 headlights use seperate H7 bulbs for dip / main and the ph3 'crystal' headlights have much better looking clear covers and look really good with the inner masks sprayed black Smile
If i was given that dturbo to improve i would definitely put some ph3 sideskirts on, fix the filler flap, ph3 colour coded side trims, ph3 bonet and bumpers then just work on getting it really really tidy and mechanically sound Smile Maybe some GTi6 front breaks (283mm discs) to add to the recipe Smile
Team Cyril
I have 3 306 so was looking at swapping the lights from my petrol one, would attempt the black mask but last time I cracked the light so trying to avoid[emoji23] I have a few things I want to do to it just wanted a few ideas
Best thing would be to swap engines with me ninja That will definitely give you some work, changing the rings... lol
[Image: 90eb3f52ead26c06fe40f4bc513a4d9f.jpg] not the best pic but lights are changed [emoji108]?
Done a few more little mods getting there slowly can anyone point me in the right direction on the best guide for fuel pump tuning?
Looks nice!
Wheres that first photo taken with the water?
Just outside Stranraer it's a little boat slipway
Fit a front mount intercooler, a bigger turbo then then keep piling in the fuel and boost till you break something, fix or repeat and then keep piling in the fuel and boost till you break something else ad infinitum.
HX35 & 11mm bosch. 4" exhaust out the bonnet. F**k off FMIC. Water meth. GTi6 brakes. Lower it. Tint it. Polish it. Maybe get some nice wheels and decent tyres.
That's what I'd do... Tongue
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
[Image: d8db00b8963313ee76e4f5e8f53cf621.jpg] anyone's on here?
^ Rear suspension looks broken.
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
Just seen this go past earlier, back end is LOW lol. Adam tells me you knocked on the door while we were out, sorry i missed you.
indeed fella; like i said; pop on the forum what you are looking for. I'm sure if there is anything available we can sort you out.
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
Looks good, but if it was my car, I would raise the rear a bit. So it looks more ready to go fast stanced. And not so much "My arse is hungry, so Im just going to eat these rear wheels" Tongue
But I guess not. If you are into the scrape thing Smile
Thanks guys yea not often you drive down the road and see 2 on the same drive haha had to stop in on the way back past. It is a bit low but it surprisingly not bad when it comes to speed bumps or that
