Threads: 38
Car Model/Spec: D'turbo S
Given 1 thank(s) in 1 post(s)
I've dissembled my pump and wondering what the best way to clean the bits that are exposed to the outside world; main block and top. I've gone at it with brake cleaner and a wire brush whilst it almost does it, it still leaves a load of crap. I was thinking could I soak them in hot water maybe abit of soap, rinse, stick them in the oven on a low heat evaporate it all off then Dw-40 and brake cleaner for extra measure I want it shining
Threads: 87
48
Wire brush attachment on a drill mate
Threads: 38
Ok I'll see what I can find
Threads: 87
48
That's how I did mine, go for the softer brass coloured ones, used a bit of brake cleaner to soften the old veg off too lol
Threads: 38
Oooh that's lovely I think I'll do mine I've got some black and red so guess it'll be that. what did do to clean it? Gunna have a walk into town see if I can find any drill attachments but not got much hope :/
And did you just put it back together the just go nuts and spray everything?
Threads: 371
29
Car Model/Spec: ford fiesta
12mm head!! Are you going mega power then? From what I see the levers inside all need changing for a 12mm head
Threads: 38
25-09-2015, 10:04 PM
(This post was last modified: 25-09-2015, 10:14 PM by blinkyeatu.)
I've reassembled it but just thinking should the lever be pressed right up against the governor then require quite abit of pressure to press it back? As I remember it moved quite freely
Dw I've got it
Threads: 26
2
Car Model/Spec: 306 xud twin turbo compound
Given 2 thank(s) in 2 post(s)
Looking well man u any pictures of the left over washer to make sure it's not important :-)
