Brake disc weights. 6 and 302mm.
Anyone got a spare 6 disc lying around they could weigh.
And a 302mm 307 disc.
I am thinking Dumdum might.
may havea '6 one. will look in abit
As for the 302 ones, there heavy.
[Image: sig.jpg]
front 306 246mm 4.14kg
rear 306 247mm 2.57kg ...307 (246.5mm) 3.04
front 306 266mm 4.7kg ....307 266mm 5kg
front 306 283mm 5.95kg... 307 283mm 6.74kg
front................................307 302mm 8.42kg
weights taken from eurocarparts website
Good find there cully, did not think to look there.
1.68 kgs extra per corner. I wonder if the bigger discs will give much more braking power than I already have. Might just use gti6 discs when the hi spec ones have given up.
  Wheel weights Niall 13 8,077 30-07-2014, 07:04 PM
Last Post: daddyfixit
  new disc brake Rear beam pioneer DJ paddy 8 5,441 22-07-2014, 05:58 PM
Last Post: pioneer DJ paddy
  306 HDI Rear Disc Brake to Drum Brake Setup Switch MY95 18 11,926 01-01-2014, 09:34 PM
Last Post: MY95
