10-09-2015, 06:16 PM
Hi guys, been a while since i posted anything here, hope all are well
Have a few questions im hoping i can get answered....
So far my HDI has done 163400 ish miles and has had the following replaced in the last 18 months;
2xCrank pulleys
Brown relay
Washer pump
HP Pump
Turbo
Alternator
Rear axle
Rear shocks
Top mounts
nearside front ball joint
Injectors
lift pump
Aux belt
Timing belt
disks and pads
oil filter
fuel filter
nearside abs sensor
nearside fog light
handbrake cables
clutch cable
heater control panel
2x potentiometers.... which brings me to question #1
I still need to replace engine mounts (question#4) rear axle bushes, offside rear brake caliper and wiring loom
seriously, is it normal to go through this many parts!!?!?! Im sure i missed some out too!!
Question #1;
So far ive been through 2 Potentiometers and am in need of a 3rd - could there be an underlying problem or is this a common fault with the unit?
Question #2;
So i de-cated my exhaust and bought an aftermarket straight through and fitted myself with no dramas and no issues (Sounds great!) then i let the garage replace my alternator and they must have disturbed the pipe cos now it rattles off the sub frame badly in idle and under hard acceleration. Now i know my engine mounts are worn and need replacing (Question #4) but would they be worn enough to cause the vibration?
- also.... (leading into Question #3)
Question #3;
...my exhaust whistles between 23 - 26k revs and was told it was the turbo on its way out then had it replaced after it blew but the whistle is still there and was whistling before i decated it, sometimes runs sweet and isnt a sound there at all but most of the time it whistles and sometimes screams like mad (when i say whistles and screams i mean its very audible!) i have been advised that it could be the back box or the turbo but there is no loss of power, no smoke and its perky, the turbo seems fine and the turbo has more of a hiss sound than a whistle so i doubt its that, there is a distinct whistle note in the rev range, the whistle seems to resonate through the whole exhaust so i cant really pinpoint where its coming from although does sound slightly more noisy toward the engine - could the whistle issue be caused by worn engine mounts causing excessive movement of the exhaust/engine union?? Or is it more likely the back box?
Question #4
I have looked on the internet, in the Haynes manual and done a physical check myself but still cant seem to find how many engine mounts there are on a 306 HDI 90 - 2000 RHY- i have identified 3 so far - are there 3? or more? also my rear axle bushes need replacing so... i want to go poly bush can anyone recommend a half decent set, again, i looked for a set but cant seem to find one anywhere so need to know what they are individually, would it be worth going poly for the rear axle or does it not matter?
Question 5#
Last one for now!
So i need to do an oil change and my pug has done 163K + last oil change was straight drain and replace, this time im going to have a clean out with cheap oil first before putting in the good stuff, i also bought some engine flush - to my knowledge the car has never been thoroughly cleaned prior to new oil being added - now my mate advised against this as it stands a chance of lowering the oil pressure due to residue build up in key areas of the motor - is this right? or can i go ahead and use the engine flush?? also any recommendations on oil would be great - im looking at fully synthetic but is there much difference in brand etc?
Really appreciate some answers and I know you guys will deliver so muchos appreciation in advance!!
Cheers lads
2xCrank pulleys
Brown relay
Washer pump
HP Pump
Turbo
Alternator
Rear axle
Rear shocks
Top mounts
Injectors
lift pump
Aux belt
Timing belt
disks and pads
oil filter
fuel filter
nearside abs sensor
nearside fog light
handbrake cables
clutch cable
Question #1;
Question #2;
Question #3;
Question #4
Question 5#
Last one for now!
Cheers lads
