transmition noise
mot in april and started to drive the car for about a week after my other one was written off. on the advisory loist it said gear box oil leak and gear box noisy. never had an issue with the gear box and sounded fine to me nothing heard while ddriving untill i stopped at some lights and as i pulled away and had gone a few feet this is the sound i get from the car. its a 1.4 meriadian made of cheese and tinfoil so i have been told LOL any ideas?
how do i upload a video it ony gives me two options and neither work
Best upload video to youtube and link it here.
If it's grinding or whining it's probably knackered lol, I've killed a few on 1.4s. lol
(30-08-2015, 03:13 PM)Toms306 Wrote: Best upload video to youtube and link it here.
have you ever watched an old prissoner of war film were they dig the tunnel from were they are doing a concert and sneek out during the show and they have built a hand crank machine with rubber flaps to make it sound like clapping? that the closest thing i can liken it too lol
That's the best description of a noise I've read in a while... lol
Rubber claps doesn't sound like gearbox though, it should be a metallic noise! Sounds more like an arch liner has dropped from that. Get that video up lol.
[video=facebook]http://[video=facebook]https://video-lhr3-1.xx.fbcdn.net/hvideo-xfp1/v/t42.1790-2/11917363_10153177384263108_1507676332_n.mp4?efg=eyJybHIiOjY2NywicmxhIjo1MTJ9&rl=667&vabr=371&oh=d05a03f905a58e372a7aa153e15e8918&oe=55E3A317http://[/video][/video]
It's not working. Confused
lets see if this workssorry for the quality could not up load to you tube so had to use the web cam on my laptop to record the phone
this is getting bejond a joke trying to load this video
https://youtu.be/R5xYNP3Q9zQ
(02-09-2015, 04:33 PM)gazthegnome Wrote: lets see if this works sorry for the quality could not up load to you tube so had to use the web cam on my laptop to record the phone
thank Jebus it worked lol
its the knocking sound you hear but it not metalic sounding and you only get it when moving
Hmm, tbh it's hard to tell from that. Sounds more like a driveshaft there. Confused Could be a bearing in the 'box though, it's not the same noise as I had in either of mine.
Don't know how competent you are but could you drain the gearbox oil? See if the magnetic drain plug is full of iron filings or even a gear tooth?
took the plug out and it had loads of filings on it
Sounds f*cked tbh, but there's a lot of background noise, it's hard to tell. For it to be mentioned on the mot it must have been fairly bad.
Loads of filings probably means it's f*cked then. Should only be a few at most.
I've just drained the oil from my 1.4 and found gear teeth on the plug, yet it didn't sound like that! Mine would do the typical clunk on tight & slow left hand corners. Is that sound whilst on the move or at idle?
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
