Threads: 25
Car Model/Spec: 306 cab
31-07-2015, 04:14 PM
(This post was last modified: 31-07-2015, 04:15 PM by insomaniac45.)
Hey guys,
Have a few issues here, the fans do not come on.
I do however have a bit of a leak in the system, and a new rad is on order, But is the fact it wont hold pressure the cause for the fans to not come on?
Btw shes a
year 2000
2.0l Cabriolet
Tony.
Not always Grumpy!!
306 Cabby SE, 2.0l 16v
Threads: 23
Car Model/Spec: 306hdi
is there a fan switch on the rad??? if so take the wire out and put a wire across both wire. if that works replace the fan switch.
306 HDI
stage 1+ remap
piper cross air filter
hoffmann race centre pipe
hoffmann de-cat pipe
sportex rear tailbox 3"
Threads: 25
sweet, will try that asap.
Not always Grumpy!!
Threads: 23
Did it work??
306 HDI
stage 1+ remap
Threads: 25
:embarrassed:
I have not had chance to yet, been so hectic here. i am hoping tomorrow is the day my new rad is here, if it arrives, i will be working on the car, so i will double check then
Not always Grumpy!!
Given 117 thank(s) in 116 post(s)
Assuming it has AC (does a cabby need ac!?) there will be 3 sensors on the stat housing. Unplugging one of these (can't remember which off top of my head, someone else will) should bring the fans on as a failsafe.
If anything, a leak should bring the fans on more! So I will guess that you have another fault...
Threads: 465
114
Car Model/Spec: Vauxhall
Given 97 thank(s) in 92 post(s)
If the sensor is in am air pocket it won't read the true temperature
Threads: 25
Well, i have now fitted my new radiator,
EIS Radiator from Eurocar parts, she now holds a steady 70c  she was sat there for 20 mins at that temp. so im happy there.
The fans Do work, as i unpluged the middle plug, and they both came on. and yes, it does have aircon. but it does not get cold. so i think the system needs a re-charge.
So, because i have air-con, how do i go about making sure the system is ok. or is it something i will have to just wait and see on?
Tony.
Not always Grumpy!!
Threads: 42
28
have the system vacuum tested, if it holds, get it charged with a leak detecting dye, off you go.
it wont affect the operation of the fans insofar as they will still cool the engine sufficiently, but they do operate differently when the AC is on.
Threads: 25
thanks for the reply.
I will look into getting the system checked asap.
Tony.
Not always Grumpy!!
