Threads: 26
29-07-2015, 10:54 PM
(This post was last modified: 29-07-2015, 11:01 PM by pioneer DJ paddy.)
Threads: 61
11
Haha this is a great idea
Can't wait to see it stink or sail
Threads: 8
Car Model/Spec: xtdt 306
Country:
This is brilliant. Will it float?
Threads: 371
29
Car Model/Spec: ford fiesta
You should get a will it float or will it sink bit going brainiac style. Lol.
Threads: 26
Thanks lads hopefully it float lol only time will tell :-)
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
You have too much time Paddy.
81
jesus.... Hope you dont plan on moving anywhere with a lawnmower engine and that engine housing. Have you got a prop for it?
I think you may need more sealant as well...
Threads: 26
(30-07-2015, 08:29 AM)Eeyore Wrote: jesus.... Hope you dont plan on moving anywhere with a lawnmower engine and that engine housing. Have you got a prop for it?
Sill need to get a prop but the fella I got the lower unit off said he has one to suit this so should be Ok as for the lawnmower engine will try it first and if everything works Ok then I will buy something bigger lol
Done a bit more work last night so will get photos of that later
And the thing don't have that much free time lol just wanted aanother thing to do :-)
Threads: 0
45
You are absolutely nuts but I love it. It's like your own Scrapheap challenge lol.
Threads: 8
Car Model/Spec: 405 SRDT
Given 6 thank(s) in 6 post(s)
Bonkers Paddy, love it lol. Cant you just cut a big hole in the floor, add an engine and big fan, bit of a skirt and hovercraft it? That'd be cool
Threads: 26
Thanks jj and paul lol should be interesting :-) probably a lot of wet feet before I get it right lol
306s aren't all that watertight on land, I get the feeling you're gonna get wet even if it does float.
Threads: 26
30-07-2015, 10:17 PM
(This post was last modified: 30-07-2015, 10:20 PM by pioneer DJ paddy.)
Pmsl this should be funny, how are you going to keep her upright?
Threads: 62
Car Model/Spec: Megane 265 + SHB Gti 6
31-07-2015, 07:05 AM
(This post was last modified: 31-07-2015, 08:43 AM by Lwilliams.)
2 strapped buoys either side? topgear challenge transit van thing ftw!
Threads: 19
31-07-2015, 08:29 AM
(This post was last modified: 31-07-2015, 08:30 AM by mr_fish.)
She's a bit ripe paddy.
expanding foam....lots of it
following with keen interest though.
Threads: 26
31-07-2015, 10:32 AM
(This post was last modified: 31-07-2015, 10:36 AM by pioneer DJ paddy.)
(31-07-2015, 06:58 AM)Poodle Wrote: Pmsl this should be funny, how are you going to keep her upright?
Hopeing floats In the right places will keep her balanced we will just have to see need to try and get it sum way water tight first
(31-07-2015, 08:29 AM)mr_fish Wrote: She's a bit ripe paddy.
expanding foam....lots of it ![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png)
Thanks fish and lwilliams lol should be interesting
81
jesus that has to be the worst rust ive ever seen in the rear arch! good luck!
I suspect you'll need some ballast a way underneath, else she'll be pretty unstable. What's the plan to get it watertight, seam weld and seal all the way up to the window line..?
Threads: 202
58
Ballast won't help much here unless you're going out in big waves. Primary stability will be high, it's flat bottomed so will be very hard to flip over on flat water. The concern is the lack of secondary stability. Lean it far enough on a wave or by loading one side too much, and it'll suddenly lose the battle and roll over. It'll likely need a lot of angle to do that though, maybe 40* or so of lean.
I'd be cutting the roof off in case it sinks though, watching with interest!
02-08-2015, 02:22 PM
(This post was last modified: 02-08-2015, 02:25 PM by Poodle.)
Yes Jonny, and putting a bit of ballast a little way under the vehicle would solve that problem, that's the whole idea. If it's a little way from the floor it's effect will be greater the more it tips, leverage yo.
Threads: 202
58
(02-08-2015, 02:22 PM)Poodle Wrote: Yes Jonny, and putting a bit of ballast a little way under the vehicle would solve that problem, that's the whole idea.
Not as much as you'd think. It's already got the primary stability from being flat bottomed. The way around it would be to fabricate some sort of hull with the ballast in the bottom, effectively making it into a displacement hull and meaning lots of work. Yes, ballast in the bottom would give the feeling of more stability but it would also be slower to recover from large roll angles, making it easier to capsize in waves. Look at small flat bottomed power boats, they carry almost no ballast for that exact reason.
02-08-2015, 02:46 PM
(This post was last modified: 02-08-2015, 02:47 PM by Poodle.)
Yeah, but that's inside the hull, i'm talking about putting it a little way under the vehicle, ie about 50cm down or so, like a centre board with a lump on the end. I'm sure there's probably a proper boaty term for it, but i've no idea what it might be.
You'll just have to trust me on it, worked beautifully on our raft.
Threads: 202
58
Yeah it'll feel more stable if you do that. But if you're gonna be playing with real waves there's a lot more to consider. I'm probably over complicating this a bit TBH, it'll either sink or float. Stability can be discussed if it floats
Threads: 186
38
Car Model/Spec: MG ZR VVC
Well it's different ![lol lol](https://www.306oc.co.uk/forum/images/smilies/legacy/lol.gif) what if it sinks though? how will you get it back out? or is it a case of get in the truck and leave quickly
(02-08-2015, 03:48 PM)lolsteve Wrote: Well it's different what if it sinks though? how will you get it back out? or is it a case of get in the truck and leave quickly
I think he lives on a farm with a lake? Just drag it out with a tractor lol.
Threads: 26
All very good point here I'm not 100% on Wat I'm going to do underneath but was thinking of some sort of big ballast lol was all so thinking about how stable it will be but with the flat floor should be ok I hope wouldn't be taken it out it bad weather any way. so if it does sink it will be staying there:-) thanks for all the comments
Threads: 20
Car Model/Spec: Phase 1 Genoa
Just saw this thread hahaha this is brilliant. Any progress ?
Threads: 26
Haven't done mutch yet waiting for sum sort of descent weather ta get going on it again . keeping my eyes open for a cheap engine to put in it hopefully get it ready for this summer :-)
Threads: 16
Given 3 thank(s) in 3 post(s)
