20-07-2015, 05:39 PM
knock noise..any ideas?
20-07-2015, 06:15 PM
Definitely the crankshaft pulley, had the same problem not that long ago..
http://pages.ebay.com/link/?nav=item.vie...ID=EBAY-GB That's what I bought and it's been perfect since, don't buy cheap copies, get an oe part
20-07-2015, 06:47 PM
I have a billet metal pulley from lynx engineering. Can't be that dude unless that's making normal noises sound louder being solid metal???
20-07-2015, 07:57 PM
(This post was last modified: 20-07-2015, 07:59 PM by highwayman306.)
tensioner mate...i had same issue not long back
I changed the pulley with a cheap part and the new one knocked...the noise was actually the tensioner Although, i couldn't really hear much in your vid :/ Stage 1 HDi DTurbo Diablo 5dr, "Dee-Dee"
After going for a drive the noise seems quite noticeable from the timing belt / camshaft area. This noise is there hot or cold engine also. Is there anything in the head that could make this noise? Or cambelt tensioners?
(20-07-2015, 07:57 PM)highwayman306 Wrote: tensioner mate...i had same issue not long back Which tensioner was this dude?
20-07-2015, 08:09 PM
The manual tensioner on the aux / serpentine / fan belt, call it what you will
The bearing had shot and sounded like metal on metal...i still can't hear what the noise is, just sounds like a diesel...maybe its my speaker? Stage 1 HDi DTurbo Diablo 5dr, "Dee-Dee"
20-07-2015, 08:18 PM
It's hard to get sounds across over videos the noise is the dull knock sound. I will give the tensioner a change though if cheap.
20-07-2015, 08:23 PM
(This post was last modified: 20-07-2015, 08:25 PM by highwayman306.)
Your camera seems to be pretty good at picking up noise, you could try filming the sump and see if the noise is any more prominent. Tbh you may b better off taking it to a garage and seeing what they think, it's very hard to diagnose minor noises over the internet by way of video.
21-07-2015, 05:52 PM
its sounds just like mine
21-07-2015, 11:13 PM
(20-07-2015, 08:23 PM)highwayman306 Wrote: I think it was this one: Cheers dude (21-07-2015, 05:50 AM)Poodle Wrote: Your camera seems to be pretty good at picking up noise, you could try filming the sump and see if the noise is any more prominent. Tbh you may b better off taking it to a garage and seeing what they think, it's very hard to diagnose minor noises over the internet by way of video. I know it's really awkward to get decent videos :/ I'd love to take it to someone for a second opinion but I only have generic garages round my area. I'd like to find a garage that has experience with hdi engines or a diesel specialist. (21-07-2015, 05:52 PM)craig306 Wrote: its sounds just like mine Have you just accepted it or trying to track it down like me lol?
22-07-2015, 06:05 AM
Why a specialist, they're all the same anyway? Contrary to popular opinion our engines are far from unique and unless it's a specific fuel issue then a diesel specialist will most likely be less help than a normal garage.
22-07-2015, 06:16 AM
Put your ear to a screwdriver and use it like a stethoscope, could help you pin point the noise
22-07-2015, 06:39 AM
(21-07-2015, 11:13 PM)td163 Wrote:(20-07-2015, 08:23 PM)highwayman306 Wrote: I think it was this one: sometimes when you get a noise like that you cant trace, you have to wait for it to get worse,
22-07-2015, 09:32 AM
since you have a lynx pulley ( you lucky dude you ) then no harm will come if the aux drive belt is removed for a test.......?
with the aux drive belt removed, does the noise still happen. note, gates say that a crank pulley must not be run without it driving a drive belt!? so far so good with the proper gates crank pulley on our 306.
Got these to go on soon so I wont hear any noises....ever
(22-07-2015, 06:05 AM)Poodle Wrote: Why a specialist, they're all the same anyway? Contrary to popular opinion our engines are far from unique and unless it's a specific fuel issue then a diesel specialist will most likely be less help than a normal garage. Ah ok thats all new information to me, I have seen multiple time that normal garages dont tend to understand the engines. But as you said must be wrong popular opinion. As Craig has said below i'm going to wait it out a little longer see if it gets louder as I can see me emptying my wallet at a garage changing stuff! (22-07-2015, 06:16 AM)highwayman306 Wrote: Put your ear to a screwdriver and use it like a stethoscope, could help you pin point the noise Tried dude but no luck not sure if its an internal noise. (22-07-2015, 06:39 AM)craig306 Wrote:(21-07-2015, 11:13 PM)td163 Wrote:(20-07-2015, 08:23 PM)highwayman306 Wrote: I think it was this one: Yeah I am going to take your advice here and wait it out a little longer before I spend lots of money for no reason. (22-07-2015, 09:32 AM)pug306driver Wrote: since you have a lynx pulley ( you lucky dude you ) then no harm will come if the aux drive belt is removed for a test.......? Rich from Lynx has these pulleys in stock if your after one mate I have always heard two views on the running without the crank pulley belt. I have never done it and don't think I will as the sources that say it will damage the bottom end seem more clue'd up. Well that was my conclusion.
23-07-2015, 05:44 AM
You can run the engine without the belt on, providing you aren't going anywhere and its only for a bit. It only takes a minute to take the belt off and start the engine and listen. You would know straight away whether its a tensioner or not...on the aux route anyway
Nice pipes btw Stage 1 HDi DTurbo Diablo 5dr, "Dee-Dee"
23-07-2015, 01:02 PM
As above, it'll be ok for a minute. Besides, the lynx pulleys aren't damped so running one will theoretically have more or less the same effect as running one without the belt anyway.
Tbqh they'll probably understand about as much or as little as each other, but a knocking noise is a knocking noise, if you know what i mean. It really is luck of the draw, best bet is to go somewhere recommended, even then there's no guarantees. Perhaps go to a Peugeot specialist as they'll have more experience of the engine.
23-07-2015, 07:51 PM
(23-07-2015, 05:44 AM)highwayman306 Wrote: You can run the engine without the belt on, providing you aren't going anywhere and its only for a bit. It only takes a minute to take the belt off and start the engine and listen. You would know straight away whether its a tensioner or not...on the aux route anyway Sweet I will give that a try at the weekend. Will rule a few things out (23-07-2015, 01:02 PM)Poodle Wrote: As above, it'll be ok for a minute. Besides, the lynx pulleys aren't damped so running one will theoretically have more or less the same effect as running one without the belt anyway. Great info thanks mate. I am going to get it looked at soon got a few places round me that are pretty decent. Cheers |
HDI top end knock near HP pump | pugbug | 12 | 2,845 |
20-06-2015, 11:29 PM Last Post: JTaylor2005 |
