new beam.
new beam.
right. it sounds like my rear beam is shaged on my ph3 1.6. how easy is it to replace? and i was thinking about putting a 6 beam on whilst im doing it. how hadr is it to trasnsform it from drum to disk. and will the thicker torsion bar give me better handleing? what price should i be paying for a second hand beam? thanks all.
Easy to swap. If your swapping to disc you will need new handbrake cables. Tbh I wouldnt pay more than £80 for a decent '6 beam. Changing is easy too. Drop the old one off, something like 4 bolts either side. Then new one one, do the cables and bleed brakes Smile
Mint. Sounds easy enough that. Cheers matt.
Check out the below. Dunno if they do them on an exchange basis, but speak to em. Might be worth going the full hog with a gti beam if youre doing it anyway...
http://www.imaxle.co.uk/catalog/refurbis...r-axle-306
personally i would just grab one from the scrappy, easy, cheap, job done
306 HDI, soon to be XUD
Apart from you dont know what you are getting. Buying a refurbed one is a sure way of knowing that your new beam is good.
Also dont forget to remove the backbox before you drop the beam...
[Image: c6769879.jpg] TEAM TRACK CAR + An E60 530d M-Sport for the daily
also lobbs video on the tubes of you - rear beam change..
declantg Wrote:personally i would just grab one from sams house, easy, cheap, job done
corrected for truth! lol
He's right you no!
Right, ivebeen told it might be the Barings. Could this be a possibillity.
kingy Wrote:Right, ivebeen told it might be the Barings. Could this be a possibillity.
Yes it will be the bearings, thats what goes on them normally but they are £80 a set and a bitch to change plus if its been like that for a while the stub's will be fecked too............
in short, be easier if you can get a know good, used one or if you can stretch to it better still with a re-con beam, but they aren't really cheap!
Team Orange Engine Bay
again, the effort of changing bearings, you could remove and replace the beam...
And get a 6 beam on there and maybe some thicker tortion bars
But... who's to say the replacement beam doesn't have 1,000miles left in it? Might be fine when you buy it, but go again soon /justsaying
