23-06-2015, 09:37 PM
106 Track Toy
23-06-2015, 10:38 PM
whats the plan with the heavy sheet of glass in the roof?
![]() Wishes for more power...
23-06-2015, 10:50 PM
(23-06-2015, 10:38 PM)Piggy Wrote: whats the plan with the heavy sheet of glass in the roof? Still trying to work out a plan for that, riveting in a panel is the easy option. Other option is to get a non-sunroof skin. Not sure how easy that would be. I've seen a few pop up on Facebook but not very often.
24-06-2015, 05:38 AM
(23-06-2015, 09:37 PM)Nathan1305 Wrote:(23-06-2015, 08:58 PM)bashbarnard Wrote: Looks good man. Always wanted one of these. Had an xsi back in the day with those same door cards. I managed to single wiper mine with the standard mechanism and some playing. I went mental on the weight loss thing. Lol
24-06-2015, 10:51 AM
(24-06-2015, 05:38 AM)bashbarnard Wrote:(23-06-2015, 09:37 PM)Nathan1305 Wrote:(23-06-2015, 08:58 PM)bashbarnard Wrote: Looks good man. Always wanted one of these. Had an xsi back in the day with those same door cards. Yeah looking at options now, probably just hold out till I see an AX being broken. Feel a lot better progressing with this car over the old one
24-06-2015, 12:18 PM
Carbon Roof skin, You know it needs doing
24-06-2015, 12:26 PM
24-06-2015, 03:36 PM
Nathan, what the metro cup lads do, is buy a second hand sunroof, and rob it for its fittings. They cut a piece of alu or sheet of steel, the same shape and size as the sunroof panel and install the fittings off the sunroof. Then fit the panel in place.
24-06-2015, 03:42 PM
(24-06-2015, 03:36 PM)procta Wrote: Nathan, what the metro cup lads do, is buy a second hand sunroof, and rob it for its fittings. They cut a piece of alu or sheet of steel, the same shape and size as the sunroof panel and install the fittings off the sunroof. Then fit the panel in place. Yeah it seems like the cheapest option, tempted to cut some carbon to shape and making a insert for it and just bond it in
24-06-2015, 04:06 PM
I saw on one thread a guy got a piece of 10mm thick lexan and had a grove machined in all the way round that matched the sunroof lip
24-06-2015, 04:08 PM
(24-06-2015, 04:06 PM)306Dan Wrote: I saw on one thread a guy got a piece of 10mm thick lexan and had a grove machined in all the way round that matched the sunroof lip That's a pretty clever idea. Really trying to figure out what would be best. I can get hold of a non sunroof skin but will be quite pricy to get it fitted and sprayed
24-06-2015, 04:14 PM
Sheet of metal, tiger seal & a rivet gun. Get it done.
24-06-2015, 04:15 PM
24-06-2015, 04:46 PM
(24-06-2015, 03:42 PM)Nathan1305 Wrote:(24-06-2015, 03:36 PM)procta Wrote: Nathan, what the metro cup lads do, is buy a second hand sunroof, and rob it for its fittings. They cut a piece of alu or sheet of steel, the same shape and size as the sunroof panel and install the fittings off the sunroof. Then fit the panel in place. do it, as it would look neat! (24-06-2015, 04:06 PM)306Dan Wrote: I saw on one thread a guy got a piece of 10mm thick lexan and had a grove machined in all the way round that matched the sunroof lip with this idea (24-06-2015, 04:14 PM)JJ0063 Wrote: Sheet of metal, tiger seal & a rivet gun. Get it done. seen that done too, looks a bit shoddy if you ask me, but if your not planning on removing the sunroof ever again, then tiger seal that bastard in place.
24-06-2015, 05:11 PM
skins are easy to change on them, they are spot welded down through the channel and it lifts out.
90' 205 gti6 supercharged
05' Evo 9 IX GT Team eaton. Axle rebuilds please contact me for your needs. https://www.facebook.com/axlesbystef/
24-06-2015, 05:12 PM
25-06-2015, 08:26 AM
Pics aren't working for me
![]() ![]() Regarding the 8k limiter, that's just a soft unlocked ECU with a raised limit. standard limiter is 7200 and they can take the 8k limit if your not on it 24/7 ![]() The MA box is adequate if you have some mechanical sympathy! BE conversions are incredibly expensive but do-able Nathan if its of interest too you i have some polybushed wishbones and polybushed rear axle mounts ![]() ![]()
25-06-2015, 11:10 AM
(This post was last modified: 25-06-2015, 11:10 AM by Nathan1305.)
(25-06-2015, 08:26 AM)Matt-Rallye Wrote: Pics aren't working for me Thanks man ![]()
25-06-2015, 05:04 PM
(This post was last modified: 25-06-2015, 05:06 PM by Nathan1305.)
Took more of the sound deadening out today
![]() Only thing I'm struggling with is someone has glued the badge on previously and struggling to get the glue off. Any ideas on how to remove it?
26-06-2015, 07:18 AM
Just like i said mate, tiny amount of petrol on a rag too remove the glue then wash and polish bootlid!
26-06-2015, 08:46 AM
(26-06-2015, 07:18 AM)Matt-Rallye Wrote: Just like i said mate, tiny amount of petrol on a rag too remove the glue then wash and polish bootlid! Yeah I used a glue remover and the 106 badge came off fine it's seems like someone used actual glue for this one the glue residue is solid I got a bit off and it chipped some of the clear coat
26-06-2015, 08:48 AM
Try some wd40.. May work
26-06-2015, 08:55 AM
26-06-2015, 03:29 PM
(24-06-2015, 05:12 PM)Nathan1305 Wrote:(24-06-2015, 05:11 PM)Stef205 Wrote: skins are easy to change on them, they are spot welded down through the channel and it lifts out. Only if you buy a proper cage to weld in at the same time! Do you really need a smaller battery? for now couldnt you use the money else where and it have a better effect on the car? Even a micra battery would be a cheaper alternative for now after all you do weight the same as a leaf! ![]()
26-06-2015, 05:42 PM
(This post was last modified: 26-06-2015, 05:47 PM by Nathan1305.)
(26-06-2015, 03:29 PM)Stef205 Wrote:(24-06-2015, 05:12 PM)Nathan1305 Wrote:(24-06-2015, 05:11 PM)Stef205 Wrote: skins are easy to change on them, they are spot welded down through the channel and it lifts out. Haha I guess so, what would you do next? So the time has come, I've got the wheels I've been after for ages! They are pug fitment which is even better so no spacers needed! I got these for an awesome deal, just swapped my purple sleels and £70 his way and they were mine ![]()
save it for a set of wheels some correct fitment ones no spacers etc Decent tyres, suspension etc
(This post was last modified: 26-06-2015, 05:50 PM by Nathan1305.)
(26-06-2015, 05:47 PM)Stef205 Wrote: save it for a set of wheels some correct fitment ones no spacers etc Decent tyres, suspension etc Look at my post just before yours ![]()
26-06-2015, 05:55 PM
ah must of posted at the same time haha. Brakes either upgrade your pads and discs or fit some 6 calipers like we did on ours.
26-06-2015, 05:58 PM
26-06-2015, 06:05 PM
ive great success with brembo max discs or even plain brembo tbh i use them on my 4 pots
05' Evo 9 IX GT Team eaton. Axle rebuilds please contact me for your needs. https://www.facebook.com/axlesbystef/ |
