13-06-2015, 11:06 AM
Do people use specific greases in their axles or just whatever they have lying around?
![[Image: 20120704_212316.jpg]](http://i789.photobucket.com/albums/yy175/DanHargrave/20120704_212316.jpg)
Correct grease for axle rebuild?
According to my Haynes Citroen ZX manual (the Owners Workshop Manual), there is a special grease called Mobil Temp G9 for the ARB end plates and seal lips on the tube ends. Although, it does say a good Molybdenum Disulphide grease can be used instead. Halfords sell it in tubs.
The Moly grease is also used on the splines, but I have used anti-seize compound in the past. 'Those' beams came to pieces easily (read - a couple of pulls on the slide hammer) when doing my annual check/regrease/replace seals.
2001 BMW 330Ci
2012 VW High Up 1988 205 GTi 1.6 1990 205 Mi16 Thanks given by: Ben
14-06-2015, 04:02 PM
Thanks for that, don't know why I didn't think of looking in the manual! I'll get myself one of those greases soon, then just need a few fixings etc from Peugeot and should be good to go.
| Do I buy? rear brake pipe corroded, covered in grease or other material pipes | Charlie0 | 3 | 12,486 |
18-04-2019, 10:14 AM Last Post: Mighty306 |
| Is this kit correct? :) | JTaylor2005 | 9 | 5,164 |
15-12-2015, 02:08 PM Last Post: powerandtorque |
| Rich w roller bearing wishbone grease nipple size | Paul_13 | 1 | 2,099 |
31-08-2015, 11:10 AM Last Post: rryan |
