Threads: 3
4
Car Model/Spec: 1.4 Peugeot 306
Country:
Hey,
So, I recently changed out the radio in my 1.4 306. It required a harness like new radios do.
However, the little lever on the right of the console is now nonfunctional. Has anyone any experience of getting it to work?
Cheers.
Threads: 30
5
Car Model/Spec: 306 HDi Dturbo 5dr
Country:
Nope. ![Sad Sad](https://www.306oc.co.uk/forum/images/smilies/sad.png)
Short and sweet answer sorry but if you have fitted a Sony HU then you might be able to get a stick that you can fit that controls a sony. Mate of mine managed to get one but i can't find one on ebay or amazon for you... Good luck though
![[Image: 9fa12c59-0c3d-4413-968d-6a7840ff068f.jpg]](http://i693.photobucket.com/albums/vv295/highwayman306/9fa12c59-0c3d-4413-968d-6a7840ff068f.jpg)
Threads: 541
124
Most decent head unit manufacturers require an additional bit of loom to get the steering remote to work. An audio specialist like car audio security will be able to help
Threads: 77
1
Given 1 thank(s) in 1 post(s)
Yeah you need a interface adaptor, and they are specific to the make of new headunit you have just fitted, they are about 20 quid depending where you get them. I got mine off ebay iirc.
Threads: 85
8
Car Model/Spec: E90 330i
Given 15 thank(s) in 15 post(s)
An important thing to note is whether your stereo is compatible with a stalk remote.
I bought a jvc harness off Tom only to find out mine wasn't
Threads: 476
81
Car Model/Spec: 306 Rallye
yep you need the adapter... but basically ive never bothered and when i did have one it didnt work!
Threads: 21
3
Car Model/Spec: Stage 3 HDi
Given 5 thank(s) in 4 post(s)
Mine works ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png) Used a connects2 lead. you need a 206 one iirc as it has the 6 way control rather than the one listed for the 306 which has 4 way control (ph3 306 has 6 way control)
Threads: 3
4
Country:
(09-06-2015, 01:05 AM)HDi--Power Wrote: Mine works Used a connects2 lead. you need a 206 one iirc as it has the 6 way control rather than the one listed for the 306 which has 4 way control (ph3 306 has 6 way control)
206 lever you say? *Scratches chin inquisitively*
Ill check that out, cheers.
Threads: 21
3
No a 206 connects 2 lead, the lever is the same as a 306
Threads: 85
8
What are the 6 way controls? I have a ph3 and it just has volume +/- and track +/-
Threads: 70
10
Car Model/Spec: HDi Estate
Given 9 thank(s) in 9 post(s)
(10-06-2015, 01:57 PM)Iceman299 Wrote: What are the 6 way controls? I have a ph3 and it just has volume +/- and track +/- ![Confused Confused](https://www.306oc.co.uk/forum/images/smilies/confused.png)
Same, I robbed a stalk from a 406 as an experiment, and it has a rotary function for adjusting something... that is the 5+6th ways.
But not needed on my 306, I rewired the rotary controller to act as the volume adjust though as I didn't like the stalk up+down for the volume, too inaccurate on the worn contacts.
Threads: 21
3
10-06-2015, 05:48 PM
(This post was last modified: 10-06-2015, 05:49 PM by HDi--Power.)
the 4 way do volume up, volume down and track forward, track backward. The 6 way allows you to skip ahead in the track by holding the stalk in the track change position, also works backwards. The extra two functions are seeking within a track basically.
The 6 way stalk looks identical to the 4 way one, its not like a 406 one or later 206 etc
Threads: 70
10
(10-06-2015, 05:48 PM)HDi--Power Wrote: the 4 way do volume up, volume down and track forward, track backward. The 6 way allows you to skip ahead in the track by holding the stalk in the track change position, also works backwards. The extra two functions are seeking within a track basically.
The 6 way I have has a rotary section you twist, came from an early 406, looks identical to the 306, I think it's just later 406/206 that have the chunkier CANBUS style stalk. I plan to mod one of the CANBUS ones to work though as the stalk design is much more solid and useful than pushing the floppy 306 stalk around ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png) Just need to solder some micro switches into it's body.
Threads: 85
8
Ah, yeah that makes sense
Threads: 21
3
(10-06-2015, 09:13 PM)tigerstyle Wrote: (10-06-2015, 05:48 PM)HDi--Power Wrote: the 4 way do volume up, volume down and track forward, track backward. The 6 way allows you to skip ahead in the track by holding the stalk in the track change position, also works backwards. The extra two functions are seeking within a track basically.
The 6 way I have has a rotary section you twist, came from an early 406, looks identical to the 306, I think it's just later 406/206 that have the chunkier CANBUS style stalk. I plan to mod one of the CANBUS ones to work though as the stalk design is much more solid and useful than pushing the floppy 306 stalk around Just need to solder some micro switches into it's body.
No that is not the 6 way, the 6 way is as i described.
