Has anyone ever fixed a 306's air conditioning?
Use it or lose it seems to be the next common phrase when it comes to AC.
#32
(02-06-2015, 12:26 PM)curnow_doc Wrote: Use it or lose it seems to be the next common phrase when it comes to AC.
Or in the case of my Kia, use it every day and still loose it Tongue
#33
(15-05-2015, 02:00 PM)Toms306 Wrote: Blocking the rad would reduce the cooling, defeating the object.  It's not too bad a location on 306s, the fan infront does shield it a bit.  On the Focus the AC rad is right at the front, fan at the back so gets battered by stones and shit. Undecided
after I had my condenser replaced, I whipped the bumper off and fitted a strip of ally mesh (painted black) behind the grille. no more damage since. Smile
Hate Housework!
#34
Both my 306's have working air con.
My hatchback as had two condensers in it's 320k miles life so far.
Even the dog shit estate has working ac, I just replaced the rotten old condenser.
It's the salt off the roads in the winter that rots them out. I use to spray water in the grills to try and flush out the salt when washing the cars but it still rots out behind a relay box that between the fans at the top.
The salt also rots the two bottom pipes where the P clips are.
