Threads: 6
Car Model/Spec: 306td
Country:
Hi guys I currently have a 306td I've had 10 years been good as gold I also have a dispatch 1.9d that I've just pulled then engine from and have a citroen xantia td engine to fit problem is I have less then 10 days todo it and the xantia has a ecu for the bosch pump now I'm guessing it's going to be a ball ache to wire in the ecu so I'm after a pump n injectors asap if any one knows of any please help ?? andy
Threads: 36
4
Car Model/Spec: Berlingo xud / 306 gti6
Given 6 thank(s) in 6 post(s)
Not hard to wire at all just use standard loom and ecu swap senors etc to match loom and live power for pump
Job done
Threads: 6
Country:
Mines a non ecu run engine so didn't want to faff about tbh as would need to modify both looms to make 1 to work. ? tjanks for reply tho
Threads: 36
4
Opps sorry read quickly see what you mean now
