25-03-2012, 08:28 PM
Apart from the this is there any thing else i should change walst im in there?
Cam cover gasket.
25-03-2012, 08:31 PM
Toby Wrote:Paint it (the rocker cover) a lairy colour its hidden by my awesome top mount Quote:(15:06:27) Toms306: Wd40d it and had a good tug, came straight off
25-03-2012, 08:52 PM
make it shiney shiney
shiney shiney is always awesome Member of the 99% warning or you're nothing club
25-03-2012, 08:57 PM
samass Wrote:make it shiney shiney ok fine ill make it shiney shiney but not other mechanical bits and bobs that need doing whilst its opened up? Quote:(15:06:27) Toms306: Wd40d it and had a good tug, came straight off
25-03-2012, 09:04 PM
D seal perhaps...?
Give it a good ol' clean, little bit of petrol on a rag cleans it up well before you apply the new gasket. I often get it sandblasted and a coat of paint, works well, just some heatproof stuff does the job well
25-03-2012, 09:09 PM
ginge191 Wrote:D seal perhaps...? it had a new d seal a couple of months ago. so no need to change right? might get some silcone sealant around the seat to stop a boost leaks. Quote:(15:06:27) Toms306: Wd40d it and had a good tug, came straight off
25-03-2012, 09:10 PM
well i always silicone sealant the actual gasket for the rocker cover, always leaks for me just replacing the gasket. With the sealant its holding up lovely.
26-03-2012, 04:01 PM
lol at the "Xantia power"
![]() They just seem so ghey for me (gasket), probs me just buying shit ones. But meh, silicone sealant is the answer to everything for me ![]()
27-03-2012, 09:37 AM
Matty Wrote:lol at the "Xantia power" You can fix anything if you use enough of it, if it doesn't fix it then clearly you haven't used enough silicone on there ![]()
27-03-2012, 09:47 AM
Matty, you might have a warped cam cover. Not a massive problem obviously, just means a normal gasket wont seal and silocone will because its flexible/not a set shape
27-03-2012, 01:29 PM
Do NOT overtighten the 3 bolts on top hoping it'll seal.
They go into the cam caps which are EASY EASY EASY to round out, which MUST NOT be replaced by others off another head, they're line bored, so if you put on another one, you're likely to f*ck the cams/caps.. Well - you can put others on, but I'll lol when your engine is full of swarf.
27-03-2012, 01:45 PM
Ruan Wrote:Do NOT overtighten the 3 bolts on top hoping it'll seal. True that ^^
27-03-2012, 03:37 PM
Ruan Wrote:Do NOT overtighten the 3 bolts on top hoping it'll seal. Which is not a very nice thing!!!!!!!!!!!!!!!!!!!!! ![]()
27-03-2012, 03:38 PM
Dave knows ALL about this!
Honestly, I've never laughed so hard at that pub session just laughing at you and your shit car.
27-03-2012, 04:53 PM
Silicone sealant = boss.
End thread ![]() Really wouldn't be bothered if I had a warped cam cover, if it's sealed. It's sealed. No probs. Sorted. ![]()
27-03-2012, 05:52 PM
Heh overtightening is normally what makes them leak / serious overtighting rounds threads / snaps the lugs off the cam bearing caps. You need to make sure there all tight the same and not all that tight or else it just bends / leaks...If I got problems I used to just smear some hymolar around the gasket, but should be fine with new gasket / right bolts...
| #DervMafia | ![]() |
rocker cover gasket | philpemberton94 | 3 | 1,543 |
16-01-2015, 10:36 PM Last Post: Danny Wideboy |
xud rocker cover gasket | Ryan@306 | 3 | 2,259 |
07-09-2012, 12:20 PM Last Post: puglove |
