Threads: 18
Car Model/Spec: Phase 2 306 Gti 6
Hi guys,
A thing I've noticed on my 6, when I'm pulling away quickly from first gear it doesn't want to slip straight into second gear, I've gotta be careful when doing it for it to drop right into gear. No problems at all with any other gears.
All comments welcome as always.
Threads: 15
Car Model/Spec: XSi
Fluid change to the correct total oil from Peugeot. Could be clutch wear but more likely the gear oil
P1 XSi track car
2.4 LWB T4
Threads: 58
Car Model/Spec: Loads
worn teeth and syncro hub that one, common
Threads: 18
(05-04-2015, 01:37 PM)adam b Wrote: Fluid change to the correct total oil from Peugeot. Could be clutch wear but more likely the gear oil
I have a leaking driveshaft seal that I'm getting fixed at the end of the month, could this be causing it as gear box oil is slowly leaking out?
Threads: 15
Car Model/Spec: XSi
Could be, but if not then Miles will be correct.
P1 XSi track car
2.4 LWB T4
Threads: 18
(05-04-2015, 08:25 PM)adam b Wrote: Could be, but if not then Miles will be correct.
If Miles is correct how much would it be to fix?
Threads: 15
Car Model/Spec: XSi
Easier to find a known good gearbox.
P1 XSi track car
2.4 LWB T4
Threads: 18
(05-04-2015, 08:41 PM)adam b Wrote: Easier to find a known good gearbox.
So another full gear box would be needed?
Threads: 15
Car Model/Spec: XSi
Well it tends to be easier, although it can be fixed. Gearboxes aren't expensive
P1 XSi track car
2.4 LWB T4
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
Does sound like synchromesh. Had similar problems in cars, only gets worse unfortunately
Try double declutching when changing gears, may help a little
Phaes 1 GTI 6 - Onyx Black
Threads: 58
New hub is around £175.00 plus labour to install, while it's apart you may as well do the input shaft bearings and seals £50.00 and £100.00 to fit
Threads: 18
(06-04-2015, 07:11 PM)miles Wrote: New hub is around £175.00 plus labour to install, while it's apart you may as well do the input shaft bearings and seals £50.00 and £100.00 to fit
I'll mention this to my mechanic, thanks for the advice. The labour wouldn't cost me anywhere near as much as you said though as he does the work on my car at his house.
Where could I get these parts?
Threads: 58
06-04-2015, 10:35 PM
(This post was last modified: 06-04-2015, 10:35 PM by miles.)
Peugeot, I have the bearings on the shelf
Threads: 21
Car Model/Spec: Stage 3 HDi
(06-04-2015, 07:13 PM)Moonwalker Wrote: (06-04-2015, 07:11 PM)miles Wrote: New hub is around £175.00 plus labour to install, while it's apart you may as well do the input shaft bearings and seals £50.00 and £100.00 to fit
I highly doubt your mechanic will be interested in opening the gearbox himself either
Threads: 18
(06-04-2015, 11:21 PM)HDi--Power Wrote: (06-04-2015, 07:13 PM)Moonwalker Wrote: (06-04-2015, 07:11 PM)miles Wrote: New hub is around £175.00 plus labour to install, while it's apart you may as well do the input shaft bearings and seals £50.00 and £100.00 to fit
I was just thinking about fitting a reconditioned gear box if needed?
Threads: 21
Could be a good option if you want to keep the car for a number of years
Threads: 18
(07-04-2015, 07:18 PM)HDi--Power Wrote: Could be a good option if you want to keep the car for a number of years
Yeah I'm planning on keeping it and using it eventually as a summer car.
Threads: 15
Car Model/Spec: XSi
Save up and chuck in a new clutch kit, main crank seal, clutch cable and fork bushes too.
Just get a quaife in there as well...
P1 XSi track car
2.4 LWB T4
Threads: 58
I can supply recon box's to various spec's, same old thing the more new parts fitted up's the cost
Threads: 18
Thanks for the advice guys!
I'll keep you in mind Miles, by the looks of it I will be needing new parts for her, possibly a new rear beam too.
