Whining
Whining
Ive had a whining noise for some time obviously coming from the gearbox as it goes when the clutch isnt engaged, could it be a bearing? If so when can i get one from?
[Image: e0d4ac7c-727f-46a8-ae0c-d4a324a8a667_zpsyn3ibroz.jpg]
Sounds like release bearing. (excuse the pun)
Can buy them separately but 90% of people would change the whole clutch as it is a gearbox off job.
I put a low mileage box on about 8 months ago and done the clutch too i should of done it then but couldnt afford it, what damage can it do if it fails? I really would like to do it when it warms up abit really
It'll potentially damage the clutch cover if it fails and leave you unable to get gears. If you're unlucky and it disintegrates, it'll probably damage the crank sensor too.
If you released the clutch a few months back, how come you didn't you do the bearing at the same time? The release bearing comes as part of the clutch kit on HDi's or other models with a push-type clutch (it's part of the clutch cover on GTi-6 and TD models that use a pull-type clutch) so seems odd that you didn't do it at the time?
If the rest of the clutch is new, the release bearing is normally around £15-20 separately and any decent motorfactor will be able to source one.
Is it noticeable when you're driving? Release bearing is usually easiest heard at a standstill in neutral - pressing the clutch will change the noise or make it stop. If it's more when you're driving it's probably the box, check the gear oil level and quality. Also make sure there's no play in the input shaft bearing.
(26-02-2015, 06:53 PM)Poodle Wrote: Is it noticeable when you're driving? Release bearing is usually easiest heard at a standstill in neutral - pressing the clutch will change the noise or make it stop. If it's more when you're driving it's probably the box, check the gear oil level and quality. Also make sure there's no play in the input shaft bearing.
It only seems to do it when im slowing down using the engine mainly 3rd and 2nd
From that I'd say gearbox bearings. Could check for noisy wheel bearings before you pay out for a refurb box but that wouldnt explain the noise dissapearing when the clutch pedal is depressed.
Yup sounds like box bearings.... Release bearing will make noise at idle but go as soon as you begin to press the pedal. If box bearings the noise will remain until the clutch is fully disengaged and no drive goes to the box.
Does that mean a new box?
I used to get whining under hard acceleration and at speed. I just drive a bit slower now when the missus is in the car.
(09-03-2015, 09:39 AM)Shawnobi Wrote: I used to get whining under hard acceleration and at speed. I just drive a bit slower now when the missus is in the car.
I get the exact same noise lol
This one's fairly easy to sort out, but not a cheap fix by any means: buy her a car of her own. It'll save you money long-term with the massively reduced cost of repairing alloys and tracking and clutches, not to mention the immeasurable improvement in your own driving pleasure, so worth doing imo.
is it when your accelerating or de-accelerating?
  Whining very slow hdi... Tom 28 12,293 05-03-2014, 06:54 PM
Last Post: Poodle
