Threads: 210
Car Model/Spec: Ph1 White Gti6/306 DTurbo
Given 7 thank(s) in 7 post(s)
06-03-2015, 04:40 PM
(This post was last modified: 06-03-2015, 04:42 PM by Nathan1305.)
Door cards are done and straps in place  pretty happy with them just need to find a way to secure them in place. Any tips?
[attachment=22011]
And now have just 1 ram thing holding the boot up. Debating taking that one out as well don't really need to open the boot for long periods of time
[attachment=22012]
Threads: 26
Car Model/Spec: Peugeot 406 Coupe 3.0 V6
Given 15 thank(s) in 13 post(s)
Drill & rivets. By far the most secure and easy
Threads: 210
(06-03-2015, 04:49 PM)Pebbles167 Wrote: Drill & rivets. By far the most secure and easy
Yeah was thinking that, kinda want to keep the smooth look but can't think of anything
Threads: 26
It looks better with rivets imo. Looks sturdy and well built. If you measure properly and use larger rivets it will look very professional.
Threads: 102
9
agreed, as if you need to get behind there, you can just drill the rivets out.
Threads: 210
06-03-2015, 05:01 PM
(This post was last modified: 06-03-2015, 05:03 PM by Nathan1305.)
(06-03-2015, 04:59 PM)Pebbles167 Wrote: It looks better with rivets imo. Looks sturdy and well built. If you measure properly and use larger rivets it will look very professional.
Fair point  I'll get some rivets soon. Happy with the progress. Hopefully getting the brakes sorted out end of the month
(06-03-2015, 05:01 PM)procta Wrote: (06-03-2015, 04:49 PM)Pebbles167 Wrote: Drill & rivets. By far the most secure and easy
Yeah will make access easier I suppose. Can't wait to get it on track!
Threads: 102
9
just remember to make things easy for access and upgrades. there was a link on ebay that does a Perspex kit for these,
http://stores.ebay.co.uk/templarperforma...7675.l2563
Threads: 210
(06-03-2015, 06:08 PM)procta Wrote: just remember to make things easy for access and upgrades. there was a link on ebay that does a Perspex kit for these,
Yeah I do want polycarbonate windows but at the moment I'm gonna keep the glass ones. I'll have to re make my door cards haha won't need the window winder when I get poly windows
Threads: 0
45
For the ease of it I'd leave the boot ram in place. It doesn't weigh anything surely?!
Threads: 210
(06-03-2015, 06:13 PM)JJ0063 Wrote: For the ease of it I'd leave the boot ram in place. It doesn't weigh anything surely?!
Every gram counts haha but yeah I'll leave the 1 it just about holds the boot up. If you knock the top of it it's starts too close
Threads: 102
9
also check out my new centre console for ideas for this,
Threads: 210
(06-03-2015, 06:17 PM)procta Wrote: also check out my new centre console for ideas for this,
Ooo I like that I need to find gauges to put in, what basic ones could I add to this?
Threads: 102
9
06-03-2015, 06:30 PM
(This post was last modified: 06-03-2015, 06:32 PM by procta.)
(06-03-2015, 06:22 PM)Nathan1305 Wrote: (06-03-2015, 06:17 PM)procta Wrote: also check out my new centre console for ideas for this,
just the ones I have in mine now,
oil temp,
water temp
oil pressure,
you could put in a volt meter too
here is few ideas for yours
http://www.ebay.co.uk/itm/Subaru-Impreza...48470bbeb4
http://www.ebay.co.uk/itm/Triple-gauge-p...25a13b1fe6
http://www.ebay.co.uk/itm/Triple-Gauge-P...51bffce174
http://www.ebay.co.uk/itm/3-GAUGES-POD-C...4635d7a920
Threads: 0
45
Corr, heavy old gauges.
Who needs gauges?
Threads: 210
06-03-2015, 06:38 PM
(This post was last modified: 06-03-2015, 06:39 PM by Nathan1305.)
(06-03-2015, 06:30 PM)procta Wrote: (06-03-2015, 06:22 PM)Nathan1305 Wrote: (06-03-2015, 06:17 PM)procta Wrote: also check out my new centre console for ideas for this,
oil temp,
water temp
oil pressure,
May see if they will fit in this space if not I'll get gauge holders like that
[attachment=22018]
Threads: 102
9
06-03-2015, 07:17 PM
(This post was last modified: 06-03-2015, 07:20 PM by procta.)
(06-03-2015, 06:36 PM)JJ0063 Wrote: Corr, heavy old gauges.
Who needs gauges?
got to have gauges if you want to keep an eye on the main piece of hardware
(06-03-2015, 06:38 PM)Nathan1305 Wrote: (06-03-2015, 06:30 PM)procta Wrote: (06-03-2015, 06:22 PM)Nathan1305 Wrote: (06-03-2015, 06:17 PM)procta Wrote: also check out my new centre console for ideas for this,
oil temp,
water temp
oil pressure,
for that a flat piece of plastic mounted on that piece of trim. With the holes cut out for the switches and gauges.
Threads: 210
(06-03-2015, 07:17 PM)procta Wrote: (06-03-2015, 06:36 PM)JJ0063 Wrote: Corr, heavy old gauges.
Who needs gauges?
oil temp,
water temp
oil pressure,
Yeah that's what I'm thinking of doing  I made that cardboard template and going to make a panel out of the plastic I made the door cards out of
Threads: 102
9
yeah that will do the job, some have even made carbon fibre jobs too, well you can get the wrap to add that bit bling to the car.
Threads: 210
(06-03-2015, 08:37 PM)procta Wrote: yeah that will do the job, some have even made carbon fibre jobs too, well you can get the wrap to add that bit bling to the car.
I have carbon wrap here. I'll ise the plastic I have already and just wrap it
Threads: 102
9
are you getting shot of the heater matrix?
Threads: 210
(06-03-2015, 08:46 PM)procta Wrote: are you getting shot of the heater matrix?
Yeah will be  need to get a bypass hose and possibly a restrictor. Plus need to find out how to remove it without it pissing out water all in the car haha
Threads: 102
9
(06-03-2015, 08:50 PM)Nathan1305 Wrote: (06-03-2015, 08:46 PM)procta Wrote: are you getting shot of the heater matrix?
you will have to drain the coolant off for that job pal,
Threads: 26
Have you considered keeping the heater? They are very useful for colder days, which are most of the time In the UK. Sure, the standard one isn't as light as an expensive aftermarket job, but it's not much heavier.
Threads: 210
(06-03-2015, 09:09 PM)Pebbles167 Wrote: Have you considered keeping the heater? They are very useful for colder days, which are most of the time In the UK. Sure, the standard one isn't as light as an expensive aftermarket job, but it's not much heavier.
Don't really want to keep it, it's all ripped out now apart from the matrix. Getting some black rivets for extra style points haha http://pages.ebay.com/link/?nav=item.vie...1209381871
Threads: 102
9
(06-03-2015, 09:15 PM)Nathan1305 Wrote: (06-03-2015, 09:09 PM)Pebbles167 Wrote: Have you considered keeping the heater? They are very useful for colder days, which are most of the time In the UK. Sure, the standard one isn't as light as an expensive aftermarket job, but it's not much heavier.
Nathan, can you weld or know someone who can?
as some of the racers I know when they have build their cars, do away with the holes in the shell, that's been left after they have removed various stuff, like the air blower box and heater matrix.
Threads: 210
(06-03-2015, 09:34 PM)procta Wrote: (06-03-2015, 09:15 PM)Nathan1305 Wrote: (06-03-2015, 09:09 PM)Pebbles167 Wrote: Have you considered keeping the heater? They are very useful for colder days, which are most of the time In the UK. Sure, the standard one isn't as light as an expensive aftermarket job, but it's not much heavier.
Yeah I have a welding qualification just don't have the equipment
Keep your matrix there fella. Much simpler.
Then if you do need it, simple fan and cowling lash up is light and very useful!
No interior results in a lot of damp/condensation. heat hugely helps to clear it
Threads: 162
21
Have you riveted the door cards yet? If not what about using a bit of silicone to keep the clean flush look?
Threads: 210
(06-03-2015, 09:38 PM)DeeTurbo Wrote: Have you riveted the door cards yet? If not what about using a bit of silicone to keep the clean flush look?
How sting will it be? When pulling the door pulls it pulls against the plastic so need to make sure it won't peel off after time
Threads: 102
9
all depends on what stuff you use, as you do get some strong panel glues that body shops use now.
