04-03-2015, 09:16 AM
has anyone got any videos of bad injector noise as I think this could be the cause of my loud engine and if the injectors are making this noise do they do it all the time or come and go?
injector noise
04-03-2015, 09:20 AM
Pretty sure when injectors start to 'tick' the noise goes away at 2,500 RPM. Someone will confirm this though.
04-03-2015, 09:22 AM
ah not good my noise gets worse the more I cain it haha
04-03-2015, 09:33 AM
I'm pretty sure my injectors are on the way out tick like f*ck when i boot it
More like 3.25k when injector tick stops, its when the pre-injection stops.
Can hear the standard tick on this vid (over the bangin' choonz even!) and note how it stops dead at 3250rpm, if yours don't then I'd suggest theres something else wrong. https://www.youtube.com/watch?v=ac9YPwcsTQU
04-03-2015, 09:39 AM
Yeah ticky injections tend to stop at about 2.5 3k ish.
If its all the time id assume it would be valves/timing side of things
04-03-2015, 09:58 AM
hmm well I bought the car properly cheap because it was knocking since then ive put stage 1+ map on and done 8000 miles of well not slow driving and it hasn't got even the slightest bit worse ill really try and listen out for what revs it does it on the way home today, if it isn't injectors has anyone else got any other ides what it could be?
04-03-2015, 10:24 AM
As i said above.. But get a video up of the noise.. Could be a few things
04-03-2015, 10:28 AM
just took it for blast the tick/knock stops at 3k
04-03-2015, 11:35 AM
run some two stroke oil 200ml per tank fill up should quieten them a little
![]() https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
04-03-2015, 11:52 AM
Is the 2 stroke oil alright for CR stuff, and what does it actually do? Someone on Ford OC recommended I try some....
04-03-2015, 12:28 PM
ill give that a go mate
04-03-2015, 01:14 PM
04-03-2015, 01:39 PM
Seems to be fairly popular on tdoc, some even claim they've gained mpg.
04-03-2015, 01:44 PM
if I was to change the injectors is it more than likely that all 4 need doing or is it usual just one or two problem ones?
04-03-2015, 01:57 PM
Im still abit worried to try it in mine haha
04-03-2015, 02:26 PM
With 2 stroke it doesnt matter as long as its low ash
04-03-2015, 03:04 PM
have been running two stroke oil in my HDi's since ive had them
like i say 200ml per tank full of fuel seems to improve mpg and quieten the engine a little ![]() added benefit is the two stroke will clean the injectors too allegedly cheaper the better two stroke oil low ash mineral I'm using https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
04-03-2015, 03:59 PM
(04-03-2015, 03:04 PM)cully Wrote: have been running two stroke oil in my HDi's since ive had themSo is it noticeably better than using things like redex?
04-03-2015, 04:16 PM
(04-03-2015, 03:04 PM)cully Wrote: have been running two stroke oil in my HDi's since ive had them Hmm, might give t a go then. ![]()
Used to get the Wilko low ash stuff irrc, was cheap and helped quieten them a bit.
Adding Biodiesel really helped shut them up, could defiantly tell the difference in noise when I was back to just using pump diesel However biodiesel is one of this risky things that some say the CR system doesn't like it as it's too thick. I used it for 2 years and had nothing explode on me, just a clogged FPR which was fixed with a quick blast of wd40. However this may not be the case for everyone so dont just assume bio is a-okay
05-03-2015, 12:09 AM
I used to run two stroke oil in my mk4 golf tdi non pd and i swore by it. I wasn't sure about using it in the hdi, my injectors are well noisey so I'll definately be picking a bottle up in the morning. Just out of interest, do the injectirs finally fail or they just stay noisey and not effect the running?
05-03-2015, 12:17 AM
morisons supermarket pump diesel contains a higher quantity of biodiesel which i put down to killing a set of my injectors be warned
bio diesel has a greater cleaning effect which blocked my injectors causing a lumpy running like on 3 cylinders https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
05-03-2015, 06:46 AM
As a rule injectors will just stay noisy and not affect running, however it is still possible for them to cause issues later on, same as anything really.
05-03-2015, 08:10 AM
07-06-2015, 08:32 PM
quick Q.
would this be related to the '2-stage' injector pump.? (think Haynes describe it as a 3rd pump piston operating for acceleraton)
It goes, it stops (as reqd).
![]() Hate Housework!
08-06-2015, 09:22 PM
When i changed my injectors for some 076 ones, i needed a diesel specialist to come out and remove one of the injectors as it was seized solid, we talked about the ticking and he stated that my old ones were indeed corroded inside witch would have reduced their performance but however even brand new injectors will tick due to the design of a diesel common rail injector, the more fuel that they are required to inject and the quicker the louder they will get.
For example he just had some brand new tractor ones fitted and he said they are nearly deafening when up close, thats just the way they are. Some manufactures just counteract the problem with lots of sound ending Jake
09-06-2015, 05:33 AM
Thanks for the post Jake, it's been stated before but it really helps to have people like yourself reinforce the message with informative posts like that.
09-06-2015, 09:20 AM
There is a certain noise that happens with these injectors and after listening to a few of them, I'm now wondering if infact isn't the injector itself, it's actually the preinjection duration being too long - that's what causes that "marbling" noise or "tacking" noise which I *think* is an overly large pre-injection, I can only assume this is due to either weak solenoids not able to pull the valve back fast enough, causing an oversized pre-injection.
This would explain why it immediately shuts up at ~3000rpm since it suddenly turns off. |
A new random noise?! Injector Leak? | td163 | 3 | 1,260 |
17-12-2015, 06:18 AM Last Post: Poodle |
Injector noise | Steve1990 | 9 | 1,807 |
27-04-2015, 12:02 AM Last Post: dylan.jones95 |
