Lexia Software
Lexia Software
Not sure if this sin the correct section but here goes...
I'm retro fitting cruise control to my 63 plate Citreon Berlingo. Just reading up online and I will need Lexia Software to activate it once I've fitted the switch. Is this just same as Peugeot Planet? Or if I need the Citreon Software where can I get it?
Cheers
Citroen software is normally on the same disc as the peugeot one. Its identical just with different info for the different models.
Nice one cheers!
Where can I buy it from? I'll need the lead for the laptop too.
Just search peugeot planet on eBay and see what comes up. Lots do normally Wink
Found it for around £90? With cables ect.
But it says it will only work on a 32 bit operating system! Both my laptops are 64 is there a way around this?
