GI / WIW GTI6
GI / WIW GTI6
Right, looking to see what the 6 is worth, as much as I love the car and still can't quite get over that I'm doing this but I've got a wedding to pay for and can't afford to run this anymore
Most of you know it
Black 6 136k miles engine has 113k on it MOT until July/August not sure which
Have all the history for the new engine and for this car
It's been well looked after, when the engine was swapped had new clutch and throttle cables, new bakerBM engine mounts and gear linkages, new clutch and clutch bushes, driveshaft seals and 2 CV boots
Air con still works very well which is rare, heater matrix was changed 12 ago
It's had recent new rear discs that haven't seen much use
Genuine thermostat and housing replaced at 119k
Replacement good condition axle
Replacement NSR brake caliper and pipe
Replacement p bushes and tracking
Wishbones replaced at its first mot in my ownership
Replacement ICV due to issues with it stalling
Front lowering springs -40mm
Lower strut brace
Blue brake calipers
White inlet manifold and deresonator bung
White/blue cam covers
Blue centre console and gear knob insert
Carbon vinyl wrapped door rub strips
Phase 3 de-wipered tailgate and spoiler
Phase 3 headlights with clear lenses
Team Heko wind deflectors
K&N cone filter
Lockwood white dials
Bad points
Quite a few stone chips on the bonnet one about the size of a 5p
Small scuff on the corner of the front bumper
Lots of wear on the seat base of the drivers seat
Fog lights aren't working although this could just be a fuse or the bulbs
Pictures in my project thread
Id say knowing its probably been looked after well and its black which is quite a popular colour, about £1600 ish
(08-02-2015, 07:21 PM)Niall Wrote: Id say knowing its probably been looked after well and its black which is quite a popular colour, about £1600 ish
Jesus that sounds incredibly high?! I don't know the car but if its absolutely mint I suppose it could be?!
GTis are getting more and more expensive for tidy ones. Yes you can pick them up for £7-800 but they are f*cked. You look at a properly cared for one and it will be around that figure.
Bit higher than I'd been expecting tbh, it is in good condition but there are little things which id like to improve but can't justify it
Currently got clones on with decent condition federal 595s on aswell
Id have thought £1600 was way too high aswell but then again im northern and tight!
Id still be umming & ahhing at 1k if im being honest,
But theres not alot of them floating about at the min so might be a good time to sell and get decent money.
Its a phase 2. It seems to be sorted now but id be surprised if you get more than 1000. I reckon 900 will see it go.
