Threads: 11
Car Model/Spec: 1999 306 DT
Hi all did an oil change two days ago some reason I was fapping around and put to much oil in it car is now puffing out white smoke! Can't drain it until the weekend, will it cause any damage to my engine if I drive it??
Cheers.
Threads: 110
20
It's not ideal having to much oil in. There is the possibility the turbo will pick it up and run on it. How much to much you put in?
Too much oil shouldn't make it white smoke though
Threads: 11
05-02-2015, 11:42 PM
(This post was last modified: 05-02-2015, 11:42 PM by CJRODELL.)
put in about 2.5 litres give or take it might of been cause it was cold, but it only smokes white after i did the oil change!
Threads: 110
20
Bit of a strange 1. I would say try and avoid driving it as 2.5 litres is a fair bit extra
Threads: 11
(06-02-2015, 12:24 AM)Frosty Wrote: Bit of a strange 1. I would say try and avoid driving it as 2.5 litres is a fair bit extra
Yeah will do mate I'll drain it on Saturday and start over see what happens!
How did you manage to put 2.5litres too much in!?
Threads: 11
(06-02-2015, 06:45 AM)Piggy Wrote: How did you manage to put 2.5litres too much in!?
I didn't put 2.5 litres over, 2.5 is how much I put in if that makes sense!
Threads: 122
9
Given 7 thank(s) in 7 post(s)
It should take 4.5 litres from empty
Threads: 48
Wtf....
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Threads: 19
theres 4.5l of oil required for an XUD
Threads: 11
Sorted it now guys little bit awkward didn't have enough in it and the White smoke is because only 2 of my glow plugs are working! Whoops!
Threads: 29
Car Model/Spec: 309 grdt
Threads: 87
48
Too much or nad enuff
Threads: 110
20
At least you got it sorted mate
Threads: 14
7
Given 5 thank(s) in 5 post(s)
Hope you didn't ruin the bottom end by running it too low on oil.
You had about half as much in as you should have done, thats not good if you drove it far.
Threads: 11
(06-02-2015, 02:02 PM)r3k1355 Wrote: Hope you didn't ruin the bottom end by running it too low on oil.
Didn't drive it far, topped up on oil now and it seems to be running okay and oil is at the correct level!
Glad all is well. I've limped to a services before on 2litres!
My turbo burnt a couple of litres when it failed and I kept driving it... The cam and lifters wore out shortly after the incident... Good luck.
Threads: 11
(06-02-2015, 05:47 PM)Toms306 Wrote: My turbo burnt a couple of litres when it failed and I kept driving it... The cam and lifters wore out shortly after the incident... Good luck.
ohh wow, well hopefully that won't happen to me!! (touch wood)
Threads: 226
24
Car Model/Spec: A3 TDi
Ha live and learn ay!
Threads: 11
(06-02-2015, 06:50 PM)Tom Wrote: Ha live and learn ay!
You know it mate! ha best way
oh and i cant help it anymore...
Its "too much" not "to much"
Ahhhhhhh, thats better
Nah 2.5l will have been over the oil pickup, long as you didn't get it hot and shove it into roundabouts on three wheels, you'll be OK.
Threads: 11
06-02-2015, 10:36 PM
(This post was last modified: 06-02-2015, 10:38 PM by CJRODELL.)
(06-02-2015, 07:26 PM)Piggy Wrote: oh and i cant help it anymore...
Im glad you feel at ease piggy!!
(06-02-2015, 09:53 PM)Ruan Wrote: Nah 2.5l will have been over the oil pickup, long as you didn't get it hot and shove it into roundabouts on three wheels, you'll be OK.
Yeah i literally drove it to work twice, topped up on oil today drives lovely now and oil is all good!
