arp xud head studs
arp xud head studs
hi guys im new on here im trying to find out about some arp head studs for my xud but arp dont seem to have any listed so i have found two different sets which may do the job the first one is a renault set 216 4301 these r quite short though and would fit without the 38mm spacers with just the washers that come with nut set .i have a bolt for the renault engine its 12 x1.5 mm and the lenght from underside of bolt head to end of thread is 117mm on the pug xud bolt its 119mm from the end of the bolt to the underside of the 38mm spacer so about the same.the second set ive looked at are for a honda s2000 208 4702 these obviously are 12mm x1,5 again i know the bolt lenghth its 163mm from bolt end to uderside of bolt head so these r much longer the pug bolt from top of 38mm spacer to end of bolt is roughly 145 mm so honda ones 18mm longer ,so depending on the thread lenghth and how far they will wind into the block and the thread lenghth at top end of bolt these might do the job also . ive emailed some arp dealers to try and find stud overall lengths and thread lengths of these two kits so just waiting to here back.
id be interested to hear ur thoughts on this and wether any off you guys hav any info on arps for an xud
i used to work at janspeed in salisbury gas flowing and porting heads so my xud heads been done
my engine so far
gas flowed head
piper cam
venier pully
lightened balanced end to end and overall weight balanced, stress relieved rods with mi 16 arp bolts
balanced crank , crank pulley ,flywheel gti 6
decked honed block
acl race series big ends and main bearings
new oil pump genuine pug
oil pump chain
new goetze piston rin set
citreon multi layer steel head gasket
406 inlet manifold cut ,egr removed, gas flowed and re welded
bosch 11mm pump ground lda pin
mk1 306 exhaust manifold gas flowed
just looking at turbos now think its gonna be a nissan navara 2.5 vnt turbo gta2056v 734868 5001s
oh and get these head bolts out one at a time and fit some studs
cheers vince
I have a set of ARP head studs and nuts etc. brand new unopened ready to go ThumbsUp
Get some pictures up and do a build thread sounds interesting. As for arps piggy on here recently organised a group buy. Would be the bloke to ask.
(05-02-2015, 09:17 PM)Piggy Wrote: I have a set of ARP head studs and nuts etc. brand new unopened ready to go ThumbsUp
hi m8 how much do u want for them
[attachment=21532[[attachment=21533]
looks awesome. what rods are you running? standard ones are likely to make a break for freedom with all that
(05-02-2015, 09:18 PM)bashbarnard Wrote: Get some pictures up and do a build thread sounds interesting. As for arps piggy on here recently organised a group buy. Would be the bloke to ask.
[attachment=21534]
(05-02-2015, 09:32 PM)bashbarnard Wrote: looks awesome. what rods are you running? standard ones are likely to make a break for freedom with all that
they r mk1 rods with all fracture points removed arps fitted
So they're just out a phase one. Still likely to kill them from what I've seen. At least stick some hdi ones in or some forged. Zx_volcane gets hold of forged but they are expensive. Its always a chance they will go if not.
Ps everything looks awesome. Start a build thread properly on here in sure a lot of people would love to see it.
(05-02-2015, 09:50 PM)bashbarnard Wrote: So they're just out a phase one. Still likely to kill them from what I've seen. At least stick some hdi ones in or some forged. Zx_volcane gets hold of forged but they are expensive. Its always a chance they will go if not.
oh shit that dont sound good then its revs that break rods i shant rev it past 5 k everthing is balanced even the pistons, the rods are smooth no casting marks so i hope they will be ok
Rods go/revs arent related
ARP head stud kit is £175 posted
Engine looks ace by the way Smile
id be up for those studs m8 how can we get together and sort it out
(05-02-2015, 11:12 PM)vinny Wrote: id be up for those studs m8 how can we get together and sort it out
Whats ya email or FB?
Thanks given by: vinny
Exclamation Read only???? Also head studs question ekjdm14 1 2,678 28-12-2021, 09:07 AM
Last Post: Mighty306
  Head head head studs ??? Yungpug 1 2,651 11-09-2017, 12:31 PM
Last Post: Chris_90
  ARP Head Studs WITHOUT CUSTOM SPACERS!!!! SonnyRoby 36 27,588 31-01-2016, 09:41 PM
Last Post: Piggy
