Threads: 8
Car Model/Spec: Audi A3 1.8t Sport
17-12-2014, 02:24 PM
(This post was last modified: 17-12-2014, 02:28 PM by Nath140889.)
Had two, pulled the bearing right through the pressure plate on the first one in around 3k miles, second one was fine at 28psi on a k14 and bosch turned up a fair ammount with lda ground, turbo died beforethe clutch and that clutch did around 30-40k, but for the money id go for a vaelo they are know to hold very well and are only 78quid on car parts 4 less, also that transmech is cheaper on their site rather than ebay use my old reg if u need m393lkv
Threads: 72
Car Model/Spec: 205 1.9 D Turbo (Full Gti Rep)
Given 1 thank(s) in 1 post(s)
Thanks I used your reg.
Is this the turbo clutch?
Valeo part number:641545050
Threads: 72
Just called the local mf for a valeo.. see what price he comes back with
Threads: 90
54
Waste of time, I've had people ask me to fit them before, I did twice, and both times they failed within 500 miles, release bearing / pressure plate failures, total waste of time and effort.
Threads: 371
29
Car Model/Spec: ford fiesta
Bitr the bullet and get an luk one. Always have a valeo clutch in
they are oem so should see you right. A touch more but do you really wanna risk a cheapy and take box out twice!!
Threads: 19
5
Car Model/Spec: Ph1 D-turbo(on going project)
i can get genuine exchange units for €130 plus postage to yourself
Threads: 163
53
Car Model/Spec: 406 HDI
I fitted one on my XUD Sedan years ago, lasted 3k on a tuned Lucas/K14 that dyno'ed at 114bhp, pathetically useless.
