Threads: 20
Car Model/Spec: GTi6
Does anyone know the spec of the cab rear axles in comparison to a GTi6 one?
Looking for a replacement for one of mine and can get one off a cab but I'm unsure of arb & torsion bar specs in comparison to the GTi6's
Smaller. 19mm TBs and a 18mm ARB iirc
Yep, TBs are just standard 19mm. No idea about the ARB.
18mm or 19mm I cant remember but it was small!
Threads: 20
ok thanks, will hold out for a HDI estate or xsara vts one if possible then
Threads: 0
18mm arb, that is small. I thought the cab would have larger due to the extra weight
Threads: 42
28
hasnt got the shell stiffness to make use of a larger one!
Threads: 20
was after another axle as the gti6 I'm driving at the min is extremely low (I didn't lower it) and when I tried to pull the axle apart not even the arb would come out which I've never had before...
I was going to source another axle and was offered a cab one but not too fussed now as I'm not keeping the car and it doesn't seem to scrub or catch on general driving.
