XUD not starting when hot - Compression Test
#61
Win!! Sounds promising at least Smile
HDi Cabby Project Click
#62
(10-11-2014, 07:27 PM)londondan86 Wrote: Win!! Sounds promising at least Smile
Better than promising, passed MOT today, loose nut on a rear shock but grand other than that!
So touch wood, new pump seems to have done the job. If I get a chance sometime I might strip down the old pump, see if there's anything noticeable wrong with it. Once again, cheers for all the help
#63
Excellent!! Another years motoring then!!
I'd rebuild your other pump with new seals and go from there. Probably be ok unless there are obvious signs of wear beyond repair.
  question about compression therefused 6 3,664 01-10-2013, 06:42 PM
Last Post: londondan86
  Working Out Compression ratios Daniel306 11 6,076 08-06-2012, 09:08 AM
Last Post: Dave
