EMP gauge
since I have nearly finished the manifold for the gt22 i may aswell weld a boss in for a emp reading while im at it my question is what gauge do you guys use for this any links / advice would be appreciated.
thanks ash
I'll be needing exactly same thing so I'll keep my eye on this Smile
I have a 63mm, 60 psi FlowFit one bolted to the dash. Seems to do the job.
You can use anything that will read a decent amount of pressure.
I have an autometer 60psi boost gauge - but they're not cheap. You could go for any air pressure gauge
How are you connecting the gauge to the manifold cos I can only guess that you can't use rubber boost hose lol
copper brake line and fittings. then once after from it, nylon pipe iirc...for sure there are pictures in my thread.
Yeah...see my RR first failed run for why a rubber hose is a bad idea!! lol
