Gear Linkages Fitting Guide?
Really? Job for Sunday then, should be fun
[Image: e0d4ac7c-727f-46a8-ae0c-d4a324a8a667_zpsyn3ibroz.jpg]
#32
(24-10-2014, 02:36 PM)silverzx Wrote:
(24-10-2014, 02:23 PM)LewisG Wrote: I don't how you make it sound so easy, I can only see 2 and you can't even see the other end so how do you get the clips in if you can't see the other end
Stick your hand down there and 'feel' for them. Wink
Yep this, and I found it a bitch! Glad it's out the way Tongue
#33
Not looking forward to it tbh, best get it out the way though
#34
Its easy tbh...getting the clips in is the hardest part if you're a clumsy bugger like me, prepare for several minutes spent looking for dropped clips on the driveway. Tongue
#35
(24-10-2014, 05:05 PM)Toms306 Wrote: Its easy tbh...getting the clips in is the hardest part if you're a clumsy bugger like me, prepare for several minutes spent looking for dropped clips on the driveway. Tongue
Its just so hard to see with just the battery out, surely theres another way
#36
What do you need to see? Just feel your way around...
#37
I have this to do on my HDi, but I have been putting, and putting it off. As I wasn't sure on how to remove them, i can see it been a f*ck on for me sadly.
#38
My only worry is, i get the old ones off and cant get the new ones on lol the clips are going to be the hard bit
#39
Lol, it'll be fine. Bet you'll do it in half an hour and wonder what you were worried about. Wink
#40
This is something i need to do, fair bit of slack when in gear
#41
Well I fitted the gear linkages, Wasnt that hard, to be honest the hardest part was getting the old ones off, but using a spanner worked a treat, thanks guys! Realised how bad my oil leak is, the back of the engine is soaked, its engine oil, but the level doesnt seem to be dropping so im stuck on that one
#42
(26-10-2014, 11:48 AM)LewisG Wrote: Well I fitted the gear linkages, Wasnt that hard, to be honest the hardest part was getting the old ones off, but using a spanner worked a treat, thanks guys! Realised how bad my oil leak is, the back of the engine is soaked, its engine oil, but the level doesnt seem to be dropping so im stuck on that one
Probably a minor leak that hasn't been cleaned over many years?
I thought i had a major injector seal leak until i degreased the engine and realised it was relatively minor
  Miles Solid Gear Linkages Video wainwrightj 7 8,355 02-02-2018, 08:40 PM
Last Post: wainwrightj
  Anybody fancy fitting a 5th gear synchro? Iceman299 8 5,779 11-02-2015, 12:53 PM
Last Post: Iceman299
