Anyone ducted from ph3 fog holes?
Anyone used the ph3 fog holes for cold air feeds?
Any advice what size trumpets / air duct etc they used?
Would like to order some bits up and would be better if I could get previous experiences before hand.
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
go and measure them? tbh I always think it looks odd when ducting. its going to have almost the same effect by ducting from behind the grille where its less obvious... Fog lights or rallye blanks for me!
(23-10-2014, 09:23 AM)SRowell Wrote: go and measure them? tbh I always think it looks odd when ducting. its going to have almost the same effect by ducting from behind the grille where its less obvious... Fog lights or rallye blanks for me!
I would if I had the bumper.. Angel
S14 Zenki Build
Want me to go and measure the holes in the grille where the foglights sit?
(23-10-2014, 09:52 AM)SRowell Wrote: Want me to go and measure the holes in the grille where the foglights sit?
Would be ideal and can rep you. Wink
S14 Zenki Build
so helpful there man!
107mm plastic to plastic across the hole.
107mm, 4.2", any idea what the fog blanking plate diameter is also?
Like this but nicer:
[Image: S5005033-1.jpg]
So like this:
[Image: DSC306.jpg]
S14 Zenki Build
Not sure what you mean by the fog blanking diameter?
(23-10-2014, 02:27 PM)SRowell Wrote: Not sure what you mean by the fog blanking diameter?
1) pull trousers down
2) extend tape
3) write length here
Angel
S14 Zenki Build
Done this on mine also Tongue http://306oc.co.uk/forum/attachment.php?thumbnail=17633
I'd be worried about slurping up puddles with a CAF that low down! Confused I know people do though.
(23-10-2014, 04:49 PM)Lwilliams Wrote: Done this on mine also Tongue http://306oc.co.uk/forum/attachment.php?thumbnail=17633
What size are those mate? Any more info?
(23-10-2014, 05:35 PM)Toms306 Wrote: I'd be worried about slurping up puddles with a CAF that low down! Confused I know people do though.
Meh, it's only going to point up to an open filter.
S14 Zenki Build
What way do people feed the ducting? The only obvious way I can see is under neath the radiator and then back up? I could be wrong?
This exactly what I want to do with mine, so could lwilliams provide a part number for the inserts please?
(23-10-2014, 10:33 AM)silverzx Wrote: 107mm, 4.2", any idea what the fog blanking plate diameter is also?
So like this:
[Image: DSC306.jpg]
That pic example also has a feed in the passenger morette inner light?
Team disASTOR? Itwasntme
yes razor... because MORE COLD AIR INTAKE!
/Toseland
(24-10-2014, 07:58 PM)toseland Wrote: yes razor... because MORE COLD AIR INTAKE!
Can never have enough cold air!
[Image: diablogti6_zpsc4f1a682.jpg]
[Image: New%20GTi6%20Filmstrip%20sig2_zpsu8ocrldg.jpg]
  Any holes a goal! cully 2 2,901 20-04-2013, 05:58 PM
Last Post: Matt
