15-10-2014, 05:48 PM
Hi can any1 help me my gear Box on my 306 1.6 has packed up and wondereing What gear Box are fitted to them
Gearbox help
15-10-2014, 06:02 PM
MA gearbox.
Most likely triple linkage unless its an early ph1. Same as on other PSA 1.6s of the same era (Saxo/106 etc) though they have slightly different ratios. You could use a 1.4 'box, it will physically fit but the 1.6 is supposed to be a bit stronger.
15-10-2014, 07:00 PM
Cheers mate Its a 2002 so will have the tripple
16-10-2014, 08:14 AM
Im thinking of removing the TU out my daily any day, its got a 4 month since rebuilt MA on it, with a longer 5th gear (very low rpm at 70!!)
Might sell it if you were interested...would be a good excuse to sack the fookin petrol off!! | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
16-10-2014, 11:09 AM
Buy it just so we get another epic diesel thread
26-11-2014, 09:25 PM
(15-10-2014, 06:02 PM)Toms306 Wrote: MA gearbox. all ma gearboxes are weak I went through 3 in my 1.4 I had and the saxo/106 ones have a slightly different top linkage as the angle is on the side and not on the flat, pic attached of the difference (the best I can show)
26-11-2014, 09:37 PM
There are 2 different long linkages, if you buy a box with the other tyre can just change the linkage.
27-11-2014, 11:21 PM
different bell housings too between Iron and Alloy blocks, the sport models got bigger sun and planet gears too
2016 Castle Combe GT championship class winner |
