Threads: 28
Car Model/Spec: 306 Rallye Bianca White.
Hi guys, have seen quite a few posts regarding this, but none to tell me what the difference is. Is the LUCAS unit pants and the BOSCH one the one to have or is it the other way around? I don't have a diesel, i'm just curious as to why you guys swap them.
cheers.
Threads: 266
18
Car Model/Spec: 205 DTurbo
Bosch injects at higher pressure, is tolerant to veg/oils as fuels, has a better boost/fuel control mechanism, can swap internals out of other pumps into it etc etc.
Bosch is better.
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Bosch injectors have higher break pressures, and are a little more resilliant, also, to turning up the fuel
bosch can also be screwed much more easily (the max fuel injection duration screw is on the outside of hte bosch, whereas its on the cam in the lucas meaning you have to drain the pump every time)
/Toseland
