Sounds like you need more boost...who done the map?
07-09-2014, 09:39 PM
(This post was last modified: 07-09-2014, 09:41 PM by Toms306.)
That's the problem with manual boost control and no intercooler...a hard stage 1 will always be smokey. Looks alright to me though...same as mine with the straight through.
How long ago did you clean the back of the car?
Shouldn't be very smoky on a stage 1, or ever really, the HDis don't need it. Rob's probably on the money, failing that there's most likely a problem with the map. Whatever you do, don't increase the boost on stage 1, it'll cook the intake charge and gain you the sum total of FA.
Threads: 85
8
Car Model/Spec: E90 330i
Yeah, the stage 1 you did for me doesn't smoke much at all. I enjoyed it for the best part of a couple of weeks until the clutch decided its had enough lol
Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
Given 5 thank(s) in 5 post(s)
Dragging this up, I thought I'd let you know the sootiness has cleared up loads since I changed to new Siemens MAF and refurbed TPS. The MPG started to drop from a regualr 52ish to 39. Looked for boost leaks but there was none. Took a punt on an ECP deal on the MAF (half price) and fitted with the refurbed TPS and car is much more keen to go. Much less soot now.
Just a buzzing LP pump to change now (also ordered new Siemens on the ECP deal).
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 128
21
Given 41 thank(s) in 38 post(s)
Mine smokes like a Bizotch... It's leaking more boost than a land rover leaks oil, but I haven't got around to changing it yet as I have an fmic to fit..
Only smokes when I realt Mat it..
/Toseland
