rear spoiler screws
rear spoiler screws
been given a gti rear spoiler but no screws does anyone know part number or thread pitch? thanks
Don't know the part number but know they were fairly easy to find on service box or if not sure the pug parts desk will find them easy enough
(26-08-2014, 10:39 PM)rocker8742 Wrote: Don't know the part number but know they were fairly easy to find on service box or if not sure the pug parts desk will find them easy enough
tried that local peugeot dealer all he could find was early spoiler that bolted through rear screen.
Try taking the spoiler to a local diy store and test fit a few screws?
Grind the lugs off and use tiger seal instead. Jobs a good'un. Wink
(01-09-2014, 08:54 PM)WiNgNuTz Wrote: Grind the lugs off and use tiger seal instead. Jobs a good'un. Wink
found some correct thread in homebase
Did you have fun drilling the holes? I ended up drilling too high at first and ended up with 1cm holes after i corrected it Doh
(05-09-2014, 06:08 PM)Iceman299 Wrote: Did you have fun drilling the holes? I ended up drilling too high at first and ended up with 1cm holes after i corrected it Doh
it was ok used double sided tape masking taped to spoiler, pressed against tailgate and d/s tape stuck to it i poked holes in tape before i stuck it on.
  Help need screws/bolts D turbo 0 1,765 13-07-2018, 08:26 PM
Last Post: D turbo
  Screws that hold the arch liners on DeeTurbo 12 4,343 01-02-2016, 09:46 PM
Last Post: tigerstyle
  rear spoiler naeem 7 3,787 30-12-2014, 06:50 PM
Last Post: John1.4
