21-08-2014, 09:03 PM
Bosch pump leak
21-08-2014, 09:08 PM
looks like a poss front main seal leaking and running down the back of the pump easy enough to do on the car but requires cambelt off but if ones died is stick all new seals in there tbh
21-08-2014, 09:17 PM
Typical!
So any pump wizards local :p
21-08-2014, 09:50 PM
Christ more info needed to determine that one, it could just be an injector. I can only see a slight bit of oily residue on the block which is perfectly normal. The spot on the floor sure that wasnt oil? 'cos these motors leak like a bitch. Check the exact spot where its leaking from under the car.
21-08-2014, 10:22 PM
Il report back tomorrow, definitely veg/derv tho. injectors are all A OK nothing leaking there, only spot I can see it is just below the pump as above.
22-08-2014, 08:48 AM
Veg tends to swell rubber seals so you get more leaks. Mine was leaking from the top cover.
| Slack in bosch pump? | dt_ | 14 | 12,021 |
21-10-2020, 03:41 AM Last Post: dt_ |
| Bosch pump help for newbie | PugRy | 2 | 4,522 |
05-01-2020, 09:09 PM Last Post: jamie182 |
| Bosch pump fuel screw broken | Forby | 0 | 3,139 |
12-03-2019, 06:47 PM Last Post: Forby |
![[Image: IMG_20140821_191015_zpsr9h4nsqw.jpg]](http://i247.photobucket.com/albums/gg155/apc2008/IMG_20140821_191015_zpsr9h4nsqw.jpg)
![[Image: IMG_20140821_212855_zpsvspjjwdq.jpg]](http://i247.photobucket.com/albums/gg155/apc2008/IMG_20140821_212855_zpsvspjjwdq.jpg)
![[Image: IMG_20140821_212859_zps5e5y6o6t.jpg]](http://i247.photobucket.com/albums/gg155/apc2008/IMG_20140821_212859_zps5e5y6o6t.jpg)
