bosch pump parts
Thinking about converting to bosch soon, is just a matter of swapping the pump, lines and injectors? Or is there any other parts i need to make sure i have?
Cheers!
No smoke, No poke!
That's it, and you'll need the bracket and Bosch pully. But that's it Wink
That'll do nicely, cheers! Smile
No smoke, No poke!
Arent the brackets interchangeable, ie one set of holes are for bosch pump and one set fit lucas
(27-07-2014, 03:06 PM)Nath140889 Wrote: Arent the brackets interchangeable, ie one set of holes are for bosch pump and one set fit lucas
Yup ThumbsUp
Worth mentioning its best to perhaps to cambelt at same time...water pump with it if you can afford to. All for peace of mind and getting two jobs in one done Smile
You have to extract the studs and move their position for each pump dont you?
Done the cambelt less than 5k mile ago Smile
Cheers for the help guys, will be the next purchase after a front mount!
No smoke, No poke!
If it's had a recent cambelt kit just buy the belt around £20
Team Doesn't own a 306
Personally would go bosch before front mount
[Image: av5ym8.jpg]
The bosch and front mount will be bought within a couple of weeks of each other and probably going on within a few days of each other, just getting parts together for the time being Smile
No smoke, No poke!
can confirm the stud location is slightly different for the lucas
youll see once you take th elucas pump off that there is another set of holes on the bracket itself, just remove each stud and put it in the hole next to it or your timing will be diabolical. easy.
/Toseland
  Slack in bosch pump? dt_ 14 12,198 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,589 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 3,181 12-03-2019, 06:47 PM
Last Post: Forby
