Threads: 40
2
Car Model/Spec: DTURBO
Given 5 thank(s) in 5 post(s)
I think that the ko3 is better if your runnin a stage 1 with a lucas pump. But if you have a bosch pump k14 will boost more than the ko3 and last longer into the revs with a gov mod on the pump. Neither are much good for serious power.
HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
Threads: 371
29
Car Model/Spec: ford fiesta
Its not a power thing this motor. More my daily runner to be fair. I think ill just keep the ko3 on then.
Threads: 40
2
Yeah ko3 makes for better daily anyway imo. More torqee down low.
Threads: 41
3
Car Model/Spec: 306xrdt ph1
Given 4 thank(s) in 4 post(s)
(15-04-2014, 09:23 PM)zx_volcane Wrote: Gearbox mounting will increase lag, no doubt.
Somewhat negated by running with a VNT huh
I don't suppose you even notice ?
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 31 thank(s) in 31 post(s)
(18-07-2014, 08:34 AM)nominous Wrote: (15-04-2014, 09:23 PM)zx_volcane Wrote: Gearbox mounting will increase lag, no doubt.
You get nothing for free in this world, even with a vnt.
I think it would spool quicker on a shorter manifold straight off the head.
Velocity is king.
Threads: 41
3
I know it's like a thumb suck guesstimate, AND that you've got a more elegant fannimold, but we're only talking a couple of hundred RPM right ?
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
(18-07-2014, 09:42 AM)nominous Wrote: I know it's like a thumb suck guesstimate, AND that you've got a more elegant fannimold, but we're only talking a couple of hundred RPM right ?
Yeaaaaaaah, it'll be fine. It's not exactly a preccision engineering job.
Threads: 41
3
Tom's fannimold is !!
Threads: 266
18
(18-07-2014, 10:07 AM)nominous Wrote: Tom's fannimold is !!
Oh yeah because extensive R&D went into that thing!
Threads: 127
33
(18-07-2014, 10:13 AM)silverzx Wrote: (18-07-2014, 10:07 AM)nominous Wrote: Tom's fannimold is !!
more than you think, behind all that cut up wastepipe and duct tape were some serious engineering principles
Threads: 41
3
I can't quite make out from the pics if you're t-ing into two pipes before the turbo flange or if you've got a 4 branch collector going on?
Certainly looks like you went to the effort of pairing to firing order.
Threads: 266
18
(18-07-2014, 10:19 AM)zx_volcane Wrote: (18-07-2014, 10:13 AM)silverzx Wrote: Oh yeah because extensive R&D went into that thing!
Quantum mechanic based engineering.
Threads: 8
1
Car Model/Spec: 405 SRDT
Given 6 thank(s) in 6 post(s)
(18-07-2014, 10:22 AM)nominous Wrote: I can't quite make out from the pics if you're t-ing into two pipes before the turbo flange or if you've got a 4 branch collector going on?
It's an un-equal length 4-2-1. The cylinders are paired and come together in as smooth a way as I could manage with bits available. We tried to avoid any tight radius's and made a proper 2-1 collector.
As Tom says, velocity is king :-)
Threads: 58
Car Model/Spec: v70r
Given 1 thank(s) in 1 post(s)
K14/T2 are basically the same turbo, just T2 can run more boost.
K03/GT15 are basically the same turbo, just the K03 can run more boost.
Go bigger, TD04.
Threads: 371
29
Quite happy with the standard ko3 on mine atm . maybe if I ever get round to tuning might stick on the k14 I have
Threads: 58
K14 lag a bit more, but they kick a lot harder
Threads: 371
29
Right I have been thinking. A few people on the forum are eunning vnts which is great. But from what I can see they are gearbox mounted. As much as I like to show off will they not fit down the back??
Threads: 8
1
Maybe you want to read post 3 and 5 on this thread/
Threads: 371
29
So apprently a few people have done such things. Any build threads soneone can point me toward then? Or a website that allows me to read up on turbo efficency flow size etc??
Threads: 266
18
Mr Fish mounted his 22 frame vnt down the back on his 206.
Darren mounted a 20 frame vnt down the back of a 205.
It can/has been done, has less lag, etc. Main reason for gearbox mount is ease of adjustment/replacement and as you say, the bling factor.
Threads: 41
12
Car Model/Spec: Dtractor
GT2260 down back & Large frame lorry turbo
Threads: 58
(20-08-2014, 01:02 PM)Dave Wrote: ![[Image: IMAG0064_zps0e03c0d1.jpg]](http://i585.photobucket.com/albums/ss299/Ha11elujaz0rs/IMAG0064_zps0e03c0d1.jpg)
That's absolutely epic.
Threads: 371
29
So got another turbo off a 205 lying about courtesy of pugmanxud. While my engines out AGIAN might put the one in due to non egr manifold. Anyone confirm that manis will fit and that the exhaust elbows the same? ![[Image: f73a7067fe7b9b2e97d7e72147524b10.jpg]](http://tapatalk.imageshack.com/v2/14/10/29/f73a7067fe7b9b2e97d7e72147524b10.jpg) ![[Image: a37615302ea4c8f217a233d33a28189c.jpg]](http://tapatalk.imageshack.com/v2/14/10/29/a37615302ea4c8f217a233d33a28189c.jpg) ![[Image: 495530d96361cfeb58e0cc651fb74b45.jpg]](http://tapatalk.imageshack.com/v2/14/10/29/495530d96361cfeb58e0cc651fb74b45.jpg)
The 205 it came off used to be mine so its a known good turbo aswell.
The second question of the night is ive been offered a t25 turbo off a nissan 300sx. Anygood or leave alone. Its only £20 if iq want it. Doing a big power build at start of year ready for april and insurance change over.
Threads: 100
12
Car Model/Spec: 306 dturbo Ultra Spec
T25 on my old car was pretty good. Might not be a quick to spool as other turbo's, but anyone who has been in my car will know it felt quick.
Threads: 371
29
Fair enough. I have a feeling though that the nissan ones dont fit well. Dont know why, just an inkling. When did it spool at?
Threads: 591
54
T25/T2 hybrid I believe is possible?!
Threads: 371
29
29-10-2014, 04:47 PM
(This post was last modified: 29-10-2014, 04:49 PM by bashbarnard.)
Ok may be something to look into. Easy fitment then. Just need to get hands on a t2 maybe.
Anyone on here played with hybrid t2? Still need confirmation on the mani. Because if they are the same could always bolt up a hybrid to this manifold later down the line
Threads: 100
12
Mine fitted fine behind the engine and was off a Nissan 300zx.
Can't remember the full spool time.
Threads: 371
29
300zx I meant not sx lol
Threads: 371
29
Anyhelp with the k14 pics then?
